Using object property "Hyperlink" in a field
stefan_helmer
stefan_helmer
Hi All,
When adding one object's property as a field within an mtext block, you use add something like this to your mtext block:
%<\AcObjProp Object(%<\_ObjId 8796084857520>%).TextString>%
This would pull out the contents of my object (which here, is just another piece of mtext).
What would the sytax be to pull out the "hyperlink" property in a simmilar way, or can this be done at all?
Thanks!
paullimapa
Since I don't see hyperlinks as an option in the Field Property list, this is most likely not doable with basic AutoCAD.
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
dbroad
Whenever a hyperlink is added to an object in the drawing, it becomes accessible for hyperlink fields in that drawing.  Unless you are changing hyperlinks a lot, it should be sufficient to just add a hyperlink field and pick from the list of hyperlinks in the drawing. Would that be enough for your needs?
Architect, Registered NC, VA, SC, & GA.
