Using lisp to insert block with attribute then change the value of the attribute (PROBLEM)
Kevin.Soares.Coutinho
I'm facing a problem with an autolisp code, that used to work just fine before changing my computer, the line of code is the following:
(command "-insert" "C:/Users/Kevin/Documents/AutoCAD/block.dwg" "s" "1" "0,0" "0" VARIABLE)
This command inserts a specific block from a directory, then set the scale to 1, the position to 0,0, the rotation to 0 and then sets the value of the attribute to the value contained in the variable, the problem is that after changing my computer, i cannot change the value of the attribute like this anymore, everytime i run this line, after placing the block, a window open asking me to input the value of the attribute.
This is probably a problem about the configuration, not the code, since it was working just fine after changing my computer.
hak_vz
 the problem is that after changing my computer, i cannot change the value of the attribute like this anymore, every time I run this line, after placing the block, a window open asking me to input the value of the attribute.
Check this link about variable ATTDIA
Run same name command and set it to 0
Miljenko Hatlak
pbejse
@Kevin.Soares.Coutinho wrote:
I'm facing a problem with an autolisp code, that used to work just fine ..
Ensure ATTREQ is 1 and ATTIDA is 0 by including this line on the lisp code
(setq atr (getvar 'Attreq) atd (getvar 'Attdia))
(setvar 'Attreq 1)
(setvar 'Attdia 0)
(command "-insert" "block" "s" "1" "0,0" "0" VARIABLE)
(setvar 'Attreq atr)
(setvar 'Attdia atd)
HTH
Thank you, it worked!
