using 'cal in a tool palette command string
awatt
awatt
This works as a tool palette command string:
^C^C_mleaderscale^m'cal^mgetvar(dimscale)^m
But when I insert this between two other commands, it doesn't work.
^C^C_servar^m_cmleaderstyle^mVC_Parts^m^C^C_servar^mmleaderscale^m'cal^mgetvar(dimscale)^m^C^C_mleader
The output is as follows: (The last *Cancel* is me hitting the escape key)
Command: _setvar
Enter variable name or [?] <MLEADERSCALE>: mleaderscale
Enter new value for MLEADERSCALE <1.00>: 'cal
>>>> Expression: getvar(dimscale)
Resuming SETVAR command.
Enter new value for MLEADERSCALE <1.00>: *Cancel*
Command:
Command: _mleader
Specify leader arrowhead location or [leader Landing first/Content first/Options] <Options>: 5
Invalid Input.
Specify leader arrowhead location or [leader Landing first/Content first/Options] <Options>: *Cancel*
It looks like something is being passed out of sequence, but I'm out of ideas.
Paul_Gander
You need to add a \ character at the end of the calculation so that AutoCAD uses the result as input for the current command.
Try this:
^C^Cmleaderstyle;VC_Parts;mleaderscale;'cal;getvar(dimscale);\_mleader
awatt
It works.
Why?
The page describing special characters lists that one as a pause for user input.
About Special Control Characters
Thank you very much.
