Using AMTITLE only from command line
spencer.robertsU8DLN
Message 1 of 1
Does anyone know if it is possible to:
1. Use the AMTITLE command solely from command line?
OR
2. Use lisp to ENTMAKE an entity that is compatible with the parts list functionality?
For the first, I've tried the "-" prefix and disabling cmddia to no result.
For the second, I've dumped the dxf and extended entity code for the border, titleblock and "control point" that seems to tie everything together, but entmaking as dumped just inserts everything as normal blocks.
Does anyone have any advice on how to proceed? is there any secret ACM documentation floating around that I'm unaware of?
I've attached both the DXF dump and my attempt at an ENTMAKE on the off chance my shouts into the void are heard.
Replies (0)
