06:24 AM
Hello everyone,
I'm trying to make a program to insert 8 blocks, but I'm finding some logical error.
My goal is to insert blocks, however, I would like to switch between them using the TAB key, but the program simply does not work.
If anyone can help me I would be very grateful.
(defun c:UserTAB (/ blocklist loop) (setq blocklist(list "Block01" "Block02" "Block03" "Block04" "Block05" "Block06" "Block07" "Block08") loop t) (setvar "CMDECHO" 0) (progn (princ"\n[TAB / Enter / Esc <Exit>]") (princ (strcat "\nInsert <"(car blocklist)">: ")) (while loop (setq inp (vl-catch-all-apply 'grread (list nil 8 0))) (if (vl-catch-all-error-p inp) (progn (princ "Function Canceled!") (setq loop nil) ) (progn (cond ((or (equal inp '(2 9)) (= (car inp) 3)) (setq blocklist (append (cdr blocklist) (list (car blocklist)))) (princ (strcat "\nInsert <"(car blocklist)">: ")) ) ((or (equal inp '(2 13)) (equal inp '(2 32)) (= (car inp) 25) ) (if (findfile (strcat "C:\\Blocks\\" blocklist ".dwg" "_Scale" 1 pause "" "_.Explode" (entlast))) (vl-cmdf "_.Insert" (strcat blocklist) "_Scale" 1 pause "" "_.Explode" (entlast)) ) (setq loop nil) ) ((member inp '((2 88) (2 120))) (setq loop nil)) );Cond );Progn );Case );While );Progn (setvar "CMDECHO" 1) (princ) ) (vl-load-com)
