Use INSERTOBJ command in Autolisp or equivalent
MICROCADDAER6
MICROCADDAER6
I want to insert unreferenced images file .JPG like OLE.
Have an example of INSERTOBJ or an equivalent Autolisp function?
ronjonp
Thread HERE too.
Sea-Haven
I used a add raster to our company where is that person located ? It took the floor plan and using telephone extension number located a staff member jpg. It would add around 50 jpgs automatically, person moved so just moved there phone to new location.
Anyway this is what I used as the insert part.
(setq mspace (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
(vla-AddRaster mspace name inspt 1.5 0.0)
Moshe-A
@MICROCADDAER6  hi,
to insert images you can use CLASSICIMAGE command (command "classicimage")
to insert OLE objects i suggest to use (entmake) function, explore dxf codes of OLE2FRAME object.
moshe
