Updating Revision number of multiple block placed in model space
PJha2
Observer Observer
PJha2
Observer
Observer
Hello Everyone,
I am trying to write a code to update the title block revision number for rev up. Since I have multiple title block to do the rev up. I am writing a lisp code, but its not working. I placed the codes in local folder name UpdateRev.lsp and used Appload to call. but call is not working for some reason.
any suggestion. Attached is the code:
(defun c:UpdateRev ()
(setq blkName "TB000000") ; The block name containing the revision attribute
(setq attrName "AB_REV") ; The attribute tag you want to update
;; Get all instances of the block in model space
(setq ss (ssget "_X" (list (cons 0 "INSERT") (cons 2 blkName) (cons 410 "Model"))))
;; Check if any blocks were found
(if ss
(progn
(princ (strcat "\nFound " (itoa (sslength ss)) " instances of block " blkName))
;; Iterate over each block instance
(setq i 0)
(while (< i (sslength ss))
(setq ent (ssname ss i))
(setq entData (entget ent))
(princ (strcat "\nProcessing block instance #" (itoa i)))
;; Find all attributes of the block
(setq attList (vl-remove-if-not '(lambda (x) (eq (car x) 100)) (entget ent)))
(foreach att attList
(setq attEnt (entget (cdr (assoc -1 att))))
(if (and (eq (cdr (assoc 0 attEnt)) "ATTRIB") (eq (cdr (assoc 2 attEnt)) attrName))
(progn
(setq currentVal (cdr (assoc 1 attEnt)))
(princ (strcat "\nFound attribute " attrName " with value " currentVal))
(setq newVal (format "%02d" (1+ (atoi currentVal))))
(setq attEnt (subst (cons 1 newVal) (assoc 1 attEnt) attEnt))
(entmod attEnt)
(princ (strcat "\nUpdated revision from " currentVal " to " newVal))
(princ (strcat "\nAttribute " attrName " not found in this instance"))
(setq i (1+ i))
(princ "\nNo instances of block found.")
(princ)
(princ "\nType 'UpdateRev' to increment the revision number.")
(princ)
pbejse
@PJha2 wrote:
Hello Everyone,
What does this do?
This format subfunction is missing from the code you posted @PJha2
(defun c:UpdateRev ( / blkName attrName attEnt entData currentVal newVal)
	(if (setq ss (ssget "_X"
				  (cons 2 blkName)
				  (cons 410 "Model")
    (progn
		     blkName
      (setq i 0)
	(setq attEnt nil ent (ssname ss i))
	;; Find the target TAG attribute of the block
	(setq enx (entnext (ssname ss i)))
	(while(and (null attEnt) (not (eq (cdr (assoc 0 (setq ent (entget enx)))) "SEQEND")))
	  (if (eq attrName (cdr (assoc 2 ent)))(setq attEnt ent))
	  (setq enx (entnext enx))
	(if attEnt
	    (progn
			     attrName
			     " with value "
			     currentVal
	      ;(setq newVal (format "%02d" (1+ (atoi currentVal))))
	      (setq newVal (itoa (1+ (atoi currentVal))))
	      (setq attEnt (subst (cons 1 newVal) (assoc 1 attEnt) attEnt) )
	      (entmod attEnt)
	      (princ (strcat "\nUpdated revision from " currentVal " to "  newVal ))
			   attrName
	(setq i (1+ i))
  (princ)
(princ
(princ)
Moshe-A
@PJha2  hi,
check this fix
to prevent variables confusion keep consistency...if the attribute value is a number, set it to variable convert the string to number so you can increment it and set newVal. for printing convert the number to string.
Moshe
(defun c:UpdateRev (/ blkName attrName ss  i ent ename att attList attEnt currentVal newVal)
 (if ss
  (progn
   (setq i 0)
    ; collecting enames of attributes
    (setq ename (entnext ent))
    (while (/= (cdr (assoc '0 (entget ename))) "SEQEND")
     (setq attList (cons ename attList))
     (setq ename (entnext ename))
    ); while
    ; (setq entData (entget ent))
   ; (setq attList (vl-remove-if-not '(lambda (x) (eq (car x) -1)) (entget ent)))
    ; (getstring "\n***")
     ; (setq attEnt (entget (cdr (assoc -1 att))))
     (setq attEnt (entget att))
     ; (if (and (eq (cdr (assoc 0 attEnt)) "ATTRIB") (eq (cdr (assoc 2 attEnt)) attrName))
     (if (eq (strcase (cdr (assoc 2 attEnt))) (strcase attrName))
      (progn
       (setq currentVal (atoi (cdr (assoc 1 attEnt))))
       (princ (strcat "\nFound attribute " attrName " with value " (itoa currentVal)))
       ; (setq newVal (format "%02d" (1+ (atoi currentVal))))
       (setq newVal (1+ currentVal))
       (setq attEnt (subst (cons 1 (itoa newVal)) (assoc 1 attEnt) attEnt))
       (entmod attEnt)
       (princ (strcat "\nUpdated revision from " (itoa currentVal) " to " (itoa newVal)))
      ); progn
     ); if
    ); foreach
    (setq i (1+ i))
   ); while
  ); progn
 ); if
 (princ)
(princ)
PJha2
Observer
Observer
Thanks it worked
pbejse
@PJha2
What about this line?
I left that as it is assuming its doing some special formatting? or you don't need this? do you even have that subfunction?
PJha2
Observer
Observer
atoi, converts the current attribute from str to integer. 1+ provide increment for current value."%02d" convert the incremented integer back to string, ensuring it to be 2 digit long.
pbejse
@PJha2 wrote:
...atoi, converts the current attribute from str to integer. 1+ provide increment for current value."%02d" convert the incremented integer back to string, ensuring it to be 2 digit long.
