Updating Drawing Properties before Publishing
tcoley95E9Z
tcoley95E9Z
I am working on a program that will give me prompts (day, month, year) to update my drawing properties and then publish right after. The part I'm struggling on is verifying the user input is in the correct format (MM.DD.YYYY) and then publishing once it has been verified. This is what I have so far:
(defun c:dProps (/ mmIn ddIn yyIn dateVal const)
  (setq mmIn (getstring "\n Enter Month: ")) ;Input Month
  (setq ddIn (getstring "\n Enter Day: ")) ;Input Day
  (setq yyIn (getstring "\n Enter Year: ")) ;Input Year
  (setq dateVal (strcat mmIn "." ddIn "." yyin))
  (prompt dateVal)
  (setq const 0)
  (cond
      (( /= (setq mmLen (strlen mmIn)) 2 )  (prompt "\n Incorrect Month. ") )
      (( /= (setq ddLen (strlen ddIn)) 2 )  (prompt "\n Incorrect Day. ") )
      (( /= (setq ddLen (strlen yyIn)) 4 )  (prompt "\n Incorrect Year. ") )
      (T setq const 1)
  ) d
  (while
  ;; THE PART IM STRUGGLING WITH. I WANT A FOR/WHILE LOOP WHERE 'const' IS SET  ;;TO '1'.
paullimapa
You can create a dialog box that shows drop-down lists for selection then you know for sure you’re getting the results you want
Paul Li
IT Specialist
@The Office
hak_vz
If in your code you don't need to have an option to use some antedate than use systems date variable conversion.
(defun getCurrentDate ( / today year month day)
	(setq
		today (rtos (getvar 'CDATE) 2 6)
		year (substr today 1 4)
		month (substr today 5 2)
		day   (substr today 7 2)
		mydate (strcat month "." day "." year)
(defun c:getCurrentDate nil (princ (strcat "\nCurrent date is: " (getCurrentDate))) (princ))
Miljenko Hatlak
Sea-Haven
We had a "plot stamp" in the title block that was current date in small print so could check versions published.
