Update Titleblock Attribute of entire drawings in a directory sourcing csv
sam_safinia
sam_safinia
Hi guys,
I found a lisp routine by Lee-Mac in here and I tried and spend hours to combine it with other lisp routine to update titleblock attribute of entire drawings in a directory with values sourced from a CSV file.
Here is my two code but I lost to run main routine within sub-routine.
Briefly, main routine is prompting to select csv file and then update attribute values from csv file.
The second or sub-routine is also prompting to select drawings within a folder and I'm going to apply all this changes (run 1st routine) upon entire drawings within select directory.
I appreciate any help!
(vl-load-com)
(defun rat (adoc /
        *error*
        ano
        bln bno
        csv
        ent
        flg fnb:fun
        inc
        lst
        sel str
        tag
        rat:blk rat:csv rat:ftr rat:lay
        val
    (setq rat:csv nil)
    (setq rat:ftr nil)
    (setq rat:lay t)
    (setq rat:blk nil)
    (defun *error* ( msg )
        (AA:endundo (AA:acdoc))
        (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
            (princ (strcat "\nError: " msg))
        (princ)
    (setq fnb:fun
        (lambda ( s )
            (if (wcmatch (strcase s t) "*.dwg,*.dxf,*.dwt,*.dws")
                (vl-filename-base s) s
    (cond
        (   (not (setq sel (ssget "_X" (vl-list* '(0 . "INSERT") '(66 . 1) (if rat:ftr (list (cons 2 (strcat "`*U*," rat:ftr))))))))
            (princ "\nNo Attributed Blocks found in drawing.")
        (   (and rat:csv (not (setq csv (findfile rat:csv))))
            (princ
                (strcat
                    "\n"
                    (vl-filename-base rat:csv)
                    (vl-filename-extension rat:csv)
                    " not found."
        (   (and csv (/= ".CSV" (strcase (vl-filename-extension csv))))
            (princ "\nAttribute data file must be in CSV format.")
        (   (not (or csv (setq csv (getfiled "Select CSV File" "" "csv" 16))))
            (princ "\n*Cancel*")
        (   (not (setq lst (mapcar '(lambda ( x ) (cons (strcase (fnb:fun (car x))) (cdr x))) (AA:readcsv csv))))
            (princ
                (strcat
                    "\nNo data found in "
                    (vl-filename-base csv)
                    ".csv file."
        (   (not
                (setq tag (mapcar 'strcase (cdar lst))
                      lst (AA:massoc (strcase (fnb:fun (getvar 'dwgname))) lst)
            (princ (strcat "\n" (fnb:fun (getvar 'dwgname)) " not found in first column of CSV file."))
        (   t
            (setq lst (mapcar '(lambda ( x ) (mapcar 'cons tag x)) lst)
                  ano 0
                  bno 0
            (AA:startundo (AA:acdoc))
            (repeat (setq inc (sslength sel))
                (setq ent (ssname sel (setq inc (1- inc)))
                      bln (strcase (AA:al-effectivename ent))
                      val lst
                      flg nil
                (if (or (null rat:ftr) (wcmatch bln (strcase rat:ftr)))
                    (progn
                        (if rat:lay
                            (setq val (mapcar '(lambda ( x ) (cons (strcase (cdar x)) (cdr x))) val)
                                  val (AA:massoc (strcase (cdr (assoc 410 (entget ent)))) val)
                        (if rat:blk
                                  val (cdr (assoc bln val))
                            (setq val (car val))
                        (if val
                            (foreach att (vlax-invoke (vlax-ename->vla-object ent) 'getattributes)
                                (if
                                    (and
                                        (setq str (assoc (strcase (vla-get-tagstring att)) val))
                                        (progn
                                            (setq val (AA:remove1st str val))
                                            (/= (vla-get-textstring att) (cdr str))
                                    (progn
                                        (vla-put-textstring att (cdr str))
                                        (setq flg t
                                              ano (1+ ano)
                        (if flg (setq bno (1+ bno)))
            (if (zerop ano)
                (princ "\nAll attributes are up-to-date.")
                (princ
                    (strcat
                        "\n"           (itoa ano) " attribute" (if (= 1 ano) "" "s")
                        " updated in " (itoa bno) " block"     (if (= 1 bno) "" "s") "."
    (princ)
(defun AA:al-effectivename ( ent / blk rep )
    (if (wcmatch (setq blk (cdr (assoc 2 (entget ent)))) "`**")
        (if
            (and
                (setq rep
                    (cdadr
                        (assoc -3
                            (entget
                                (cdr
                                    (assoc 330
                                        (entget
                                            (tblobjname "block" blk)
                               '("AcDbBlockRepBTag")
                (setq rep (handent (cdr (assoc 1005 rep))))
            (setq blk (cdr (assoc 2 (entget rep))))
    blk
(defun AA:readcsv ( csv / des lst sep str )
    (if (setq des (open csv "r"))
        (progn
            (setq sep (cond ((vl-registry-read "HKEY_CURRENT_USER\\Control Panel\\International" "sList")) (",")))
            (while (setq str (read-line des))
                (setq lst (cons (AA:csv->lst str sep 0) lst))
            (close des)
    (reverse lst)
(defun AA:csv->lst ( str sep pos / s )
    (cond
        (   (not (setq pos (vl-string-search sep str pos)))
            (if (wcmatch str "\"*\"")
                (list (AA:csv-replacequotes (substr str 2 (- (strlen str) 2))))
                (list str)
        (   (or (wcmatch (setq s (substr str 1 pos)) "\"*[~\"]")
                (and (wcmatch s "~*[~\"]*") (= 1 (logand 1 pos)))
            (AA:csv->lst str sep (+ pos 2))
        (   (wcmatch s "\"*\"")
            (cons
                (AA:csv-replacequotes (substr str 2 (- pos 2)))
                (AA:csv->lst (substr str (+ pos 2)) sep 0)
        (   (cons s (AA:csv->lst (substr str (+ pos 2)) sep 0)))
(defun AA:csv-replacequotes ( str / pos )
    (setq pos 0)
    (while (setq pos (vl-string-search  "\"\"" str pos))
        (setq str (vl-string-subst "\"" "\"\"" str pos)
              pos (1+ pos)
    str
(defun AA:massoc ( key lst / item )
    (if (setq item (assoc key lst))
        (cons (cdr item) (AA:massoc key (cdr (member item lst))))
(defun AA:remove1st ( itm lst / f )
    (setq f equal)
    (vl-remove-if '(lambda ( a ) (if (f a itm) (setq f (lambda ( a b ) nil)))) lst)
(defun AA:startundo ( doc )
    (AA:endundo doc)
    (vla-startundomark doc)
(defun AA:endundo ( doc )
    (while (= 8 (logand 8 (getvar 'undoctl)))
        (vla-endundomark doc)
(defun AA:acdoc nil
    (eval (list 'defun 'AA:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
    (AA:acdoc)
(vl-load-com)
(princ
    (strcat
        "\n:: UpdateTitleblock.lsp | Version 1.9 | \\U+00A9 Lee Mac "
        (menucmd "m=$(edtime,0,yyyy)")
        " www.lee-mac.com ::"
        "\n:: Type \"rat\" to run manually ::\n"
(princ)
;;(c:rat)
;; ///////opening drawings in a director ///////
(defun C:FCC (/ acapp adoc file_obj fn fold full-names-list full_name_list ) (vl-load-com) (alert "\nPlease wait a minute \nto ending of batch file operation" ) (setvar "SDI" 0) (setq fn (getfiled "Select *ANY .DWG FILE* in a desired folder : " "" "dwg" 4 ) ) (if fn (progn (setq fold (vl-filename-directory fn) full_name_list (vl-directory-files fold "*.dwg" 1) full_name_list (mapcar (function (lambda (x) (strcat fold "\\" x) ) ) full_name_list ) ) (setq acapp (vlax-get-acad-object) adoc (vla-get-activedocument acapp) ) (if full_name_list (progn (vla-save adoc);optional (mapcar (function (lambda (dwgnmame) (progn (setq file_obj (vla-open (vla-get-documents acapp) dwgnmame)) ;;here is batch function: (rat file_obj) (vla-saveas file_obj dwgnmame) (vla-close file_obj) (vl-cmdf "_delay" 200) ) ) ) full_name_list ) ) (princ "\nNo .DWG files in selected directory\n") ) ) ) (alert "Done") (princ) )
pbejse
@sam_safinia wrote:
Hi guys,
You said you "lost  to run main routine within subroutine", what part of the routine exactly are you having problems with?
Hi Sabne, from the future here, I'm also using Lee-Mac routine to update my title block and i wonder if you've finished editing this routine to update the title block of multiple drawings at once
