You just need to google VBA Excel Autocad and you will find a lot of examples about Excel controlling Autocad, this is an example of draw a line, pline and circle.
Sub Opendwg()
Dim acadApp As Object
Dim acadDoc As Object
'Check if AutoCAD application is open. If is not opened create a new instance and make it visible.
On Error Resume Next
Set acadApp = GetObject(, "AutoCAD.Application")
If acadApp Is Nothing Then
Set acadApp = CreateObject("AutoCAD.Application")
acadApp.Visible = True
End If
'Check (again) if there is an AutoCAD object.
MsgBox "Sorry, it was impossible to start AutoCAD!", vbCritical, "AutoCAD Error"
Exit Sub
End If
On Error GoTo 0
'If there is no active drawing create a new one.
Set acadDoc = acadApp.ActiveDocument
If acadDoc Is Nothing Then
Set acadDoc = acadApp.Documents.Add
End If
On Error GoTo 0
'Check if the active space is paper space and change it to model space.
If acadDoc.ActiveSpace = 0 Then '0 = acPaperSpace in early binding
acadDoc.ActiveSpace = 1 '1 = acModelSpace in early binding
End If
End Sub
Public Sub addline(x1, y1, z1, x2, y2, z2)
' Create the line in model space
Dim startpoint(0 To 2) As Double
Dim endpoint(0 To 2) As Double
Dim lineobj As Object
startpoint(0) = x1: startpoint(1) = y1: startpoint(2) = z1
endpoint(0) = x2: endpoint(1) = y2: endpoint(2) = z2
Set lineobj = acadDoc.ModelSpace.addline(startpoint, endpoint)
acadApp.ZoomExtents
End Sub
Public Sub addcirc(x1, y1, z1, rad)
' Create the circle in model space
Dim cenpoint(0 To 2) As Double
Dim circobj As Object
cenpoint(0) = x1: cenpoint(1) = y1: cenpoint(2) = z1
Set circobj = acadDoc.ModelSpace.addcircle(cenpoint, rad)
acadApp.ZoomExtents
End Sub
Sub addpoly(cords, col)
Dim oPline As Object
' add pline to Modelspace
Set oPline = acadDoc.ModelSpace.AddLightWeightPolyline(cords)
oPline.Color = col
End Sub
Sub alan1()
' This example adds a line in model space
' Define the start and end points for the line
px1 = 1
px2 = 5
py1 = 1
py2 = 5
pz1 = 0
pz2 = 0
Call addline(px1, py1, pz1, px2, py2, pz2)
End Sub
Sub alan2()
px1 = 1
py1 = 1
pz1 = 0
Radius = 8.5
Call addcirc(px1, py1, pz1, Radius)
End Sub
Sub alan3()
'Dim coords(0 To n) As Double
Dim coords(0 To 5) As Double
coords(0) = -6: coords(1) = 1:
coords(2) = 3: coords(3) = 5:
coords(4) = 7.55: coords(5) = 6.25:
col = 1
Call addpoly(coords, col)
End Sub
