Update Multiline Attribute Definition in block
I created a title block with single and multiple lines attribute definitions.
I've written a routine to insert the title block and set all attributes blank.
Then I read a file with attribute name and value.
Then I cycle thru the block and update each attribute with the values.
I can't figure out how to update the multiline attdef.
I tried using subst and entmod/entupd - doesn't work.
I tried using vla-put-MtextAttributeContent - doesn't work.
What am I missing?
Shneuph
(VLA-PUT-TEXTSTRING MYATT "NEW STRING")  worked for me.
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
I was using vla-put-MtextAttributeContent not vla-put-TextString
