thnx for your help , I really appreciate .
i got something like what you post from cadalyst , it's below ( bold one ).
but what i want is to select the attribute instead of typing it ,
(setq tagname (getstring T "Enter Tag Name: ")
I'm new here , so I try to look up about another program and replace with this .
(defun c:test (/ atb_blk)
(vl-load-com)
(if (setq atb_blk (car (entsel)))
(progn
(setq atb_blk (vlax-ename->vla-object atb_blk) txt_val nil)
(if
(and
(eq (vla-get-objectname atb_blk) "AcDbBlockReference")
(eq (vla-get-hasattributes atb_blk) :vlax-true))
(foreach
txt_str (vlax-invoke atb_blk 'GetAttributes)
(setq txt_val (cons (vla-get-TextString txt_str) txt_val))
(princ (strcat "\nTag Name: " (vla-get-TagString txt_str)))
(princ (strcat "\n\t\t\t" (vla-get-TextString txt_str))))
(princ "\nNo attribuets found:"))
(princ "\nNothing selected"))
(princ))
could you help me ?
;;TIP 1038: GMTAGS.LSP (C)1994, Ed Gyulai
;; Globally Modifies Tag Values, All Blocks
(defun C:GMTAGS ( / tagname newv ss1 len count bn en el found)
newv (getstring T "Globally Change Value to: "))
;=================create selection set=======================
(setq ss1 (ssget "x" '((0 . "insert") (66 . 1)))
len (sslength ss1)
count 0)
(repeat len
(setq bn (ssname ss1 count) ;Block Name
en (entnext bn) ;Entity Name
el (entget en)) ;Entity List
;=================loop thru block entities===================
(while (and (= "ATTRIB" (dxf 0 el))
(/= "SEQEND" (dxf 0 el)))
(if (= (dxf 2 el) (strcase tagname))
(progn
(setq el (subst (cons 1 newv) (assoc 1 el) el))
(entmod el) ;Modify List
(entupd bn) ;Update Screen
(setq found "yes") ;Found Tag?
) ;progn
) ;if
(setq en (entnext en)
el (entget en))
) ;while
(setq count (1+ count))
) ;repeat
(if (/= found "yes")
(princ "\nTag Not Found.")
(princ)
);defun gmtags.lsp
;======================dxf function==========================
(defun dxf (code elist)
(cdr (assoc code elist))
);dxf
(princ)
