Update Attribute by Layout Name
Message 1 of 9
I am the new to LISP coding. So I used @Lee_Mac's code https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/dwgprefix-and-dwgname-to-attribute-t... to make a code to update attribute according to layout (tab) name. However, all the attribute will change to one single tab name, depending on which tag I will run the script.
(command "TILEMODE" "0")
(defun c:dwgatt ( / e f i s v x )
(setq v (strcase (getvar "ctab")))
(if (setq s (ssget "_X" '((0 . "INSERT") (2 . "BLOCK") (66 . 1))))
(repeat (setq i (sslength s))
(setq e (entnext (ssname s (setq i (1- i))))
x (entget e)
f nil
(while (and (not f) (= "ATTRIB" (cdr (assoc 0 x))))
(if (= "TAG" (strcase (cdr (assoc 2 x))))
(setq f (entmod (subst (cons 1 v) (assoc 1 x) x)))
(setq e (entnext e)
x (entget e)
(princ)
(c:dwgatt)
How do I simplify the script so it will change the attribute in one single layout?
I tried to edit the code but nothing shows up.
(defun c:dwgatt ( / v s x )
(setq x (entget (ssname s 0)))
(if (= "ATTRIB" (cdr (assoc 0 x)))
(princ)
(c:dwgatt)
Charlie
Replies (8)
Message 2 of 9
ВeekeeCZ
Try
(setq s (ssget "_X" (list '(0 . "INSERT") '(2 . "BLOCK") '(66 . 1) (cons 410 (getvar 'CTAB)))))
Message 3 of 9
Lee_Mac
I would suggest the following:
            (setq e (ssname s (setq i (1- i)))
                  v (cons 1 (cdr (assoc 410 (entget e))))
                  e (entnext e)
                  x (entget  e)
                  f nil
                    (setq f (entmod (subst v (assoc 1 x) x)))
                (setq e (entnext e)
                      x (entget  e)
    (princ)
Message 4 of 9
Thanks you @ВeekeeCZ and @Lee_Mac.
Now the LISP works. I can see the set v should put inside the repeat loop.
How come there is such a variation for v?
and
(setq v (cons 1 (cdr (assoc 410 (entget e))))
Message 5 of 9
Lee_Mac
The code:
Is retrieving the value of the CTAB system variable, i.e. the name of the current layout tab.
Whereas:
Is retrieving the name of the layout in which the block reference resides.
Message 6 of 9
Thank you Lee. You are very helpful!!
Message 7 of 9
Hi @Lee_Mac again, I posted another question at update the width of specific attribute tag trying to combine the solutions from two posts.
See if you can help me out again!
Message 8 of 9
mgamiTQW42
I am LISP beginner so any help will be much appreciated.
I am trying to write lisp to update Block attribute on single layout only if layout name matches the name of layout name specified on LISP line.  In my case each drawing has four layouts with same block on all four but I wants to update on specific layout only & not on all layouts.
"PAGENO2" Block has only one attribute "PAGE_NO".
Thank you
Mehul
Message 9 of 9
Sea-Haven
Just look at get layouts if name matches what you want then make changes.
(vlax-for lay (vla-get-Layouts (vla-get-activedocument (vlax-get-acad-object)))
(if (= lay "layout name you want")
;do something
