Message 1 of 10
I found the following codes from the internet. The codes work but there is a problem. When I end the programme with ESC key, a block is formed from the last letter. However, there is no code related to the block in the codes.
What can be done to solve this problem?
(defun c:num (/ oldPref oldSuf oldStart curStr newNum
actDoc actSp oldEcho oldSize *error*)
(defun *error* (msg)
(setvar "CMDECHO" oldEcho)
(princ)
); end *error*
(vl-load-com)
(if(not num:Size)(setq num:Size(getvar "DIMTXT")))
(if(not num:Pref)(setq num:Pref ""))
(if(not num:Suf)(setq num:Suf ""))
(if(not num:Num)(setq num:Num 1))
(setq oldPref num:Pref
oldSuf num:Suf
oldStart num:Num
oldSize num:Size
actDoc(vla-get-ActiveDocument
(vlax-get-acad-object))
oldEcho(getvar "CMDECHO")
); end setq
(setvar "CMDECHO" 0)
(if(=(vla-get-ActiveSpace actDoc)1)
(setq actSp(vla-get-ModelSpace actDoc))
(setq actSp(vla-get-PaperSpace actDoc))
); end if
(setq num:Size
(getreal
(strcat "\nText size <"(rtos num:Size)">: ")))
(if(null num:Size)(setq num:Size oldSize))
(setq num:Pref
(getstring T
(strcat "\nPrefix: <"num:Pref">: ")))
(if(= "" num:Pref)(setq num:Pref oldPref))
(if(= " " num:Pref)(setq num:Pref ""))
(setq num:Suf
(getstring T
(strcat "\nSuffix: <"num:Suf">: ")))
(if(= "" num:Suf)(setq num:Suf oldSuf))
(if(= " " num:Suf)(setq num:Suf ""))
(setq num:Num
(getint
(strcat "\nStarting number <"(itoa num:Num)">: ")))
(if(null num:Num)(setq num:Num oldStart))
(princ "\n<<< Insert numbers or press Esc to quit >>> ")
(while T
(setq curStr(strcat num:Pref(itoa num:Num)num:Suf)
newNum(vla-AddText actSp
curStr (vlax-3d-point '(0.0 0.0 0.0)) num:Size))
(vla-put-Alignment newNum acAlignmentMiddleCenter)
(command "_.copybase"(trans '(0.0 0.0 0.0)0 1)(entlast)"")
(command "_.erase" (entlast) "")
(command "_.pasteclip" pause)
(setq num:Num(1+ num:Num))
); end while
(princ)
); end of c:num
(princ "\n*** Dynamic numbering tool. Type NUM to run.*** ")
