Undo begin and Undo End not getting trapped in error routine
brbowen
brbowen
In my Startup routine I have the following code.
This is what I currently use  and "._undo" "_begin" does not make any difference.
(command "._undo" "_group")
In my ending routine I have the following code:
(command "._UNDO" "_END")
If there is no error, everything works as it should.
When there is an error, such as hitting the esc key during the program execution, it displays the error below:
Command: _COPE
Inside Radius <0.25>: *Cancel*
error: Function cancelled
Cannot invoke (command) from *error* without prior call to (*push-error-using-command*).
Converting (command) calls to (command-s) is recommended.
This is what I get when I comment out this one line of code ;; (command "._UNDO" "_END") in my ending routine and then press the esc key during the program execution.
Command: _COPE
Any suggestions?
paullimapa
Try this instead of group
(command "._undo" "_mark")
Paul Li
IT Specialist
@The Office
Kent1Cooper
The simplest thing is to just do what they recommend:
(command-s "._UNDO" "_END")
There's a  (vla-...  way to go about beginning & ending Undo that gets around that by not using  (command)  for the purpose, but the simple edit should do it for you.
Kent Cooper, AIA
brbowen
Amazing how you can overlook the obivous, when it is right there in front of you!
paullimapa
if you're curious, here's the vla version:
(vla-startundomark (vla-get-activedocument (vlax-get-acad-object)))
and
(vla-endundomark (vla-get-activedocument (vlax-get-acad-object)))
Paul Li
IT Specialist
@The Office
brbowen
Great, thanks.
Kent1Cooper
and
The way I usually do that is, at the beginning:
(vla-startundomark (setq doc (vla-get-activedocument (vlax-get-acad-object))))
Then, both at the end of the routine and inside the *error* handler, all I need is:
(vla-endundomark doc)
And I include doc in the localized variables list.
Kent Cooper, AIA
