Unable to use LISP routine in AutoCAD Mechanical 2010
I am new to AutoCAD.
I need an assistance where a user is facing issue while using the LISP routine because it is no longer pointed to correct place.
Any thoughts?
DannyNL
We need a bit more information than that.
- How do you run the LISP routine?
- Are there any error messages when using the LISP? (if so what error message and include LISP)
- Is the LISP routine automatically loaded or by pressing i.e. a button on the ribbon or a toolbar?
- Is the folder where all your LISP-files are located (and maybe other support files) added to the current AutoCAD support file paths (Options->Files-> Support File Paths)
- Any other information you can tell us?
Hi DannyNL,
Thanks for your prompt response.
Actually I am unaware about the exact usage of LISP.However, the user has mentioned that it is not pointing to correct location. So I think the issue is with setting of path.
Can you assist about it,means any generic LISP that needs to be set?
Swapnil Ballal
DannyNL
Hi Swapnil,
Difficult to say. What is not pointing to the correct location?
AutoCAD Mechanical as it cannot find the LISP file that you are trying to use? In that case probably adding the folder to the support file paths in the Options will solve the issue.
Or does the LISP itself give an error as it cannot find a specific file it needs?
In that case it might help to add the folder where the needed files for the LISP are located as well to the file support paths or you'll need to post the LISP-file so we can investigate.
Hi DannyNL,
I had a word with the user. The issue had got resolved. There was an intermittent issue.
Thanks a lot for your proactive support
Swapnil Ballal
DannyNL
Good to hear the problem doesn't exist anymore Smiley Happy
