Unable to add menu pulldown at end
iwafb
Advisor Advisor
iwafb
HI All,
I'm trying to display a pulldown menu at the end of the autocad pulldowns (after the help pulldown menu). The new menu comes from a partial custom menu I created. I had done this in previous versions, but doesn't want to play now...
I'm checking the last pulldown menu index using:
(setq nextpop (rtos (vla-get-count (vla-get-menubar (vlax-get-acad-object))) 2 0))
If I then try the following to add the custom pulldown at the next available position, it doesn't work:
(menucmd (strcat "P" (rtos (+ 1 (read nextpop)) 2 0) "=Custom.POP15"))
However, I can use the following and the pulldown loads where the help menu used to be:
(menucmd (strcat "P" nextpop "=Custom.POP15"))
Using Advance Steel 2018...
Thanks in advance.
Dart
scot-65
Perhaps
to
(setq nextpop (vla-get-count (vla-get-menubar (vlax-get-acad-object))))
(itoa (1+ nextpop))
Apply the conversion at the value's call.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
iwafb
Thanks Scot,
Still the same. I don't think it the value, for some reason, Advance Steel is happy to add if it overwrites one of the current pulldowns, but not at the end (adding new pulldown).
I am finding lots of unexpected problems with Advance steel and lisp. Not sure if it's due AS working slightly different to Autocad and maybe the lisp api  is not 100%. That's what I'm putting it down to...
Forcing the pulldowns from the current profile (CUI) and it seems to be a good workaround...
Cheers.
Dart
scot-65
Perhaps try this direction?
vla-InsertMenuInMenuBar
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2016/ENU/AutoCAD-ActiveX/files...
It is giving hint to turn off the menubar, add the item, and turn back on?
Scot-65
