Turning dialog boxes in acad 2017
gert.valk
Message 1 of 8
gert.valk
How can I turn off dialog boxes in acad2017? I have tryed Filedia, cmdecho etc. wihtout any result.
Replies (7)
Message 2 of 8
ВeekeeCZ
CMDDIA?
Message 3 of 8
_gile
FILEDIA concerns file dialogs, you should also use CMDDIA for command dialogs.
Gilles Chanteau
GileCAD
GitHub
Message 4 of 8
gert.valk
When I type "style" on the command prompt after set CMDDIA to 0 the dialog box is still popping up.
Message 5 of 8
ВeekeeCZ
There command line versions of most of the commands... with a hyphen prefix.
-STYLE
Read HERE for more details.
Message 6 of 8
Kent1Cooper
The CMDDIA System Variable suppresses them for only "certain" commands [Help doesn't list them specifically].  The hyphen prefix is the easiest way to suppress them, but you can also call a command from inside an AutoLisp (command) function:
(command "_.style")
and the command-line version will be used instead of the dialog box.
Kent Cooper, AIA
Message 7 of 8
gert.valk
Many thanks for your support!!
Message 8 of 8
ВeekeeCZ
Glad to help!
