Turn on Text Frame for metxt
mschirmer
mschirmer
Is there a lisp code name for turning on text frame?  I can write it up to place a Pline around mtext or text, but I would like to use the MTExt text frame, if possible.
Ranjit_Singh
I am on 2015 so I cannot verify the below code, but try it out
(defun c:somefunc  (/ ss1 ent)
 (setq ss1 (ssget '((0 . "MTEXT"))))
 (mapcar '(lambda (x)
           (if (= (type (setq ent (cadr x))) 'ename)
            (progn (entmod (append (entget ent) '((90. 16) (63 . 256) (45 . 1.5) (441 . 0))))
            (entupd ent))))
         (ssnamex ss1))
 (princ))
If it works, play with the values in the dotted pairs to see if you get desired result.
mschirmer
Ranjit,
Thanks for the assistance.  I'm on 2016. . I received an error stating "bad DXF group: (90.0 16)".  I did an entsel and entget and the dxf info i retrieved was the following.  I'm not sure what i should be looking for.
((-1 . <Entity name: 7ffffb28330>) (0 . "MTEXT") (330 . <Entity name: 7ffff9e6980>) (5 . "3AE3")
(100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "ENTOS-LSB") (100 . "AcDbMText") (10 1762.97 370.95 0.0)
(40 . 24.0) (41 . 559.946) (46 . 155.752) (71 . 2) (72 . 5)
(1 . "Daisy Brand\\PSuite 600\\P26,279 RSF\\PEXP: 01-31-2017") (7 . "ARIAL")
(210 0.0 0.0 1.0) (11 1.0 0.0 0.0) (42 . 253.048) (43 . 145.342) (50 . 0.0) (73 . 1) (44 . 1.0))
steve_carson
Try adding a space between the 90 and the dot. It's trying to make your 90 key into 90.0.
mschirmer
Thanks Steve.  That did the trick!
mschirmer
Ranjit,
Thanks so much.  That did work after all.  I haven't understood the Lambda and mapcar so i definitely appreciate this.  It will take me some time to go back over this and figure out what you did due to our busy schedule here.  But again, thanks!
Ranjit_Singh
Glad it worked for you. There are lots of discussion online on mapcar. Here's my 2 cents. Let me know if you still have a hard time figuring it out.
