Turn layers of the objects to color 8 inside the block
vinodkl
Mentor Mentor
Message 1 of 21
vinodkl
Hello Everyone,
I hope everyone is doing well and staying safe.
I am looking for a lisp that can turn the layers of the object to color 8 inside the block. I did try searching the forum and was not able to find one.
I have been using the lisp "FIXBLOCK" but this lisp turns the objects to  "0" layer inside the block and this doesn't fix my issue.
I get floor plan from the client and I need to turn the floor plan color to "color 8" and then start placing devices on top of that. But these floor plans are made up of blocks and nested blocks, so I need to get into the block editor and then add the objects to "group filter" and then open up the layer manager and change the color of all the layers in group filter to color "8" which is tedious.
So can anyone help me out with the lisp which can do this?
Thanks in advance.
PS: I have also used the lisp "BELTB" and it doesn't seem to solve my issue.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Replies (20)
Message 21 of 21
vinodkl
lol😂😂
Yes it over Patrick and I found my solution. Thank you😀
