Turn all Mtext to text font SansSerif, and underline
skchui6159
Message 1 of 9
skchui6159
Can any body help, how can I change the all Mtext's text font to SabSerif/romand and underline in current view with lisp? Thank you
Replies (8)
Message 2 of 9
hak_vz
1) Create text style named SansSerif and select font that you want
2) run following script
(defun c:aaa (/ ss eo i)
	(setq ss (ssget "_X" '((0 . "MTEXT"))) i -1)
	(while (< (setq i (1+ i)) (sslength ss))
	(setq eo (vlax-ename->vla-object (ssname ss i)))
	(vlax-put  eo 'textString(strcat "{\\L" (vlax-get eo 'textString) "}"))
	(vlax-put eo 'StyleName "SansSerif")
	(princ)
Miljenko Hatlak
Message 3 of 9
skchui6159
The above lisp did not work.
Message 4 of 9
hak_vz
@skchui6159  You have mtext with internally changed font. Use stripmtext and remove all unnecessary formatting and assigned fonts. Than use my script .
Miljenko Hatlak
Message 5 of 9
hak_vz
Alternatively, copy all mtexts to new temp file, select all and explode. Run search and replace %%U with blank.
Convert all texts to mtexts
(defun c:t2m ( / *error* ss i )
	(defun *error* ()
		(setvar 'cmdecho 1)
		(princ)
	(setq ss (ssget '((0 . "TEXT"))) i -1)
	(setvar 'cmdecho 0)
		(command "_.txt2mtxt" (ssname ss i) "")
	(setvar 'cmdecho 1)
	(princ "\nDone!")
	(princ)
Use my script above.
Miljenko Hatlak
Message 6 of 9
skchui6159
What happen about the error:AutoCAD.Application: Key not found? Sloved by rename style, Thank
Message 7 of 9
skchui6159
The above method works! Good. Thank you very much!
Message 8 of 9
skchui6159
What is the meaning about %%U?
Message 9 of 9
Kent1Cooper
Read about it.
Kent Cooper, AIA
