Trying to load an init.lsp from a network using ACADDOC.lsp
Message 1 of 11
Hello.
I'm trying to load an init.lsp file that is located on a network for 30+ CAD users using an ACADDOC.lsp, located in the local support folders.
The idea is to have each user place the ACADDOC.lsp file in their C:\Users\user\AppData\Roaming\Autodesk\AutoCAD 2021\R24.0\enu\Support which will load the init.lsp file located on our server:  X:\CAD Management\NCS21\SUPPORT
The init.lsp is meant to change support file paths and system variables.  I would like to be able to edit one file without having to reload settings for each user individually.
The code in the ACADDOC.lsp is as follows:
(setq lisp_path “X:\\CAD Management\\NCS21\\SUPPORT”)
(if (findfile (strcat lisp_path "init.lsp"))
(load (strcat lisp_path "init.lsp"))
When starting AutoCAD it seems to find the ACADDOC.lsp file, but is not loading the init.lsp.
Any help and suggestions would be appreciated.
Replies (10)
Message 2 of 11
CodeDing
@Anonymous ,
Looks like you're forgetting a slash in there:
(setq lisp_path “X:\\CAD Management\\NCS21\\SUPPORT\\”)
Give that a try. best,
~DD
Message 3 of 11
Good suggestion, but still doesn't seem to load the init.lsp
Message 4 of 11
CodeDing
@Anonymous ,
Run this in your command line and tell me what it returns please..
(findfile "X:\\CAD Management\\NCS21\\SUPPORT\\init.lsp")
Message 5 of 11
Here you are, Sir
Command: (findfile "X:\\CAD Management\\NCS21\\SUPPORT\\init.lsp")
Message 6 of 11
cadffm
Is it a trusted path location?
Sebastian
Message 7 of 11
Yes, I've added X:\CAD Management\ to the trusted locations.
Message 8 of 11
Kent1Cooper
Those are "smart quotes" such as come from word processors, not from plain-text editors.  Change them in your acaddoc.lsp file to "dumb" or "plain" quotation marks that look the same at both ends of the string, as in the suggested test in Message 5.
Kent Cooper, AIA
Message 9 of 11
Ah ha!  That's it!  I knew it was going to be something small like that.
Thank you both for the help!
Message 10 of 11
CodeDing
@Anonymous ,
I believe Kent hit the nail on the head. Here, you can copy this if necessary.
The returned string that you provided after running (findfile ...) tells me that the file exists and the path is correct. Your small piece of code should now work.
If it's NOT working after this, then it is something else that is causing your problem.
(setq lisp_path "X:\\CAD Management\\NCS21\\SUPPORT\\")
--EDIT--
Btw, great eye Kent. Good catch. I never would have seen that. Not a common issue to run into.
Best,
~DD
Message 11 of 11
Sea-Haven
Rather than add a acaddoc.lsp why not just use Appload and add your init.lsp to "startup suite" a simple method of forcing a load, used for years with server very successfully, so if update init.lsp end user gets latest, same with custom menus always saved on server so if updated end user would get updated version on next start up.
