Trying to create a lisp that will search a Blocks Name & Description and display the blocks in a list
scohen
scohen
All,
I have been playing around with ChatGPT (I am not a programmer :-), to create a LISP routine that will search a Blocks Name & Description based upon some text a user types in, and then display the blocks that contain that search string in the command line.  ChatGPT did a good job with the name, but couldn’t figure out how to search the description.  Can anyone on here help?
Here's the code below.
(defun c:SearchBlocksByText ()
(setq searchText (getstring "\nEnter the text to search for in block names or descriptions: "))
(if (and searchText (/= searchText ""))
(progn
(setq foundBlocks '())
(setq ss (ssget "_X" (list (cons 0 "INSERT"))))
(if ss
(progn
(setq searchText (strcase searchText)) ; Normalize search text to lowercase
(repeat (sslength ss)
(setq ent (ssname ss 0))
(setq entData (entget ent))
(setq blockName (cdr (assoc 2 entData)))
(setq blockDescription (cdr (assoc 3 entData)))
(setq blockName (if blockName blockName ""))
(setq blockDescription (if blockDescription blockDescription ""))
(setq blockDescription (strcase blockDescription)) ; Normalize block description to lowercase
(if (or (wcmatch (strcase blockName) (strcat "*" searchText "*"))
(vl-string-search searchText blockDescription))
(setq foundBlocks (cons blockName foundBlocks))
(setq ss (ssdel ent ss))
(if foundBlocks
(progn
(setq blockCount (length foundBlocks))
(setq blockCountStr (itoa blockCount))
(prompt (strcat "\nFound " blockCountStr " blocks with matching text in name or description."))
(foreach blockName foundBlocks
(prompt (strcat "- " blockName))
(prompt "\nNo blocks found in the drawing.")
(prompt "\nInvalid search text.")
(princ)
Thank you in advance.
-Seth
felix.corre
you have to look for the description in the block table.
(setq TblBk (SCAN_TB))
(progn
(if ss
(progn
(foreach elt TblBk
(if (= (cdr (assoc 2 elt)) blockName)
(setq blockDescription (cdr (assoc 4 elt)))
(if foundBlocks
(progn
(princ)
(defun SCAN_TB( / tb TblBlk)
(setq TblBlk nil)
(setq tb (tblnext "BLOCK" T))
(while tb
(setq TblBlk (cons tb TblBlk))
(setq tb (tblnext "BLOCK"))
  TblBlk
Félix.
scohen
Hi Felix,
Thanks for the response, and updated code.  I'm receiving the following error, "error: File load canceled:" .  Sorry, but like I said, I barely code :-), and it’s probably missing a simple parentheses somewhere.
Thanks again.
-Seth Cohen
paullimapa
And in case there are dynamic blocks replace
with this
 (setq blockName (vla-get-effectivename(vlax-ename->vla-object ent)))
Paul Li
IT Specialist
@The Office
felix.corre
It works fine for me. The lisp to load attached.
Félix
scohen
Hi Felix,
Thanks so much!!!!  Works awesome.
-Seth
