trying to add code to standard lisps
thomas_huntFMPXR
thomas_huntFMPXR
trying to add code to the lisp below for annotative text and text size will need to add it to each argrument or can make one argument to effect each command line?
LISP:
(defun c:ldr (/ pt)
;set variables
;setq
  (setq pt1 (mapcar '- c v) pt2 (mapcar '+ c v))
;equipment pad 1
(setq pt (getpoint "\nEQUIPMENTPAD1"))
(command "mleader" pt pause "EQUIPMENT PAD 1")
;equipment pad 2
(setq pt (getpoint "\nEQUIPMENTPAD2"))
  (command "mleader" pt pause "EQUIPMENT PAD 2")
;(e)structure
(setq pt (getpoint "\nSTRUCTURE"))
  (command "mleader" pt pause "(E) STRUCTURE" "ariel anno")
);end defun
Sea-Haven
Two problems
Where is c & v coming from ?
Unable to recognize command "ARIEL ANNO"
Did you not post before similar code and had suggestions made about how to write the correct code.
paullimapa
thomas_huntFMPXR
Yes but text size, text font, and annotative function still haven't shown in latest test. So far I just have the the command activation. also C and V I figured from the creating a list in mapcar function from a coworker suggestion the debug never picked it up.
