Trouble with lisp that writes a script
Message 1 of 11
I am trying to use the following script.  I have used this before with success but my problem lies in where the script is created.  Previously it went into my C: drive but now I want it to go to a different location.  No matter how I change the path it always goes to my C: drive
;scriptautonumber lisp
;create a script for opening dwg files, regen, and saving version
(defun C:scriptautonumber ( / COUNT DIR FILENAME FILES SCRIPTNAME)
(if (setq dir (getfiled "Select the drawing directory:" "" "dwg" 0))
(setq dir (vl-filename-directory dir))
(if dir
(setq files (vl-directory-files dir "*.dwg" 1))
(if files
(progn
(setq scriptname (open "\\bvfileprd\drafting\drafting\users\c_kauffman\batchnumberupdate.scr" "w")
count 0
(while (setq filename (nth count files))
(setq filename (strcat dir "\\" filename))
(write-line (strcat "_open \"" filename "\"") scriptname)
(write-line "f2t" scriptname)
(write-line "regen" scriptname)
(write-line "f2tb" scriptname)
(write-line "_zoom extents" scriptname)
(write-line "_qsave" scriptname)
(write-line "_close" scriptname)
(setq count (1+ count))
(close scriptname)
(princ)
Replies (10)
Message 2 of 11
hmsilva
Try
(open "\\\\bvfileprd\\drafting\\drafting\\users\\c_kauffman\\batchnumberupdate.scr" "w")
Hope this helps,
Henrique
Message 3 of 11
Error.  Bad arguement typ.
Message 4 of 11
; error: bad argument type:
Message 5 of 11
hmsilva
Probably the  script file was not open...
try
(defun C:scriptautonumber (/ count dir filename files scriptname)
    (if (and (setq dir (getfiled "Select the drawing directory:" "" "dwg" 0))
             (setq scriptname (open (strcat (chr 34) "\\\\bvfileprd\\drafting\\drafting\\users\\c_kauffman\\batchnumberupdate.scr" (chr 34)) "w"))
             (setq count 0)
        (progn
            (close scriptname)
    (princ)
Henrique
Message 6 of 11
Did not work.  It ran but i cant find the script file anywhere.
Message 7 of 11
hmsilva
Is the posted path, the real path, or just a sample?
Henrique
Message 8 of 11
that is the actual path
Message 9 of 11
hmsilva
If you run this 'demo', what happens?
(defun c:demo (/ file ofile)
    (if (and (setq file (strcat (chr 34) "\\\\bvfileprd\\drafting\\drafting\\users\\c_kauffman\\batchnumberupdate.txt" (chr 34)))
             (setq ofile (open file "w"))
             (princ ofile)
        (progn
            (write-line "This is a test" ofile)
            (close ofile)
            (if (findfile file)
                (startapp "Notepad" file)
                (princ "\nFile not found... ")
    (princ)
Henrique
Message 10 of 11
It's working now.  typo
Message 11 of 11
hmsilva
You're welcome, ckauffman
Glad you got a solution!
Henrique
