Trigonometric functions Sin-1
Henrik_Lo
Message 1 of 11
Henrik_Lo
Hi
Is the a function to do this calculation by LISP I can’t find the Sin -1 function
I need to find the angle by use of formula a/c*sin-1
My example : 1.4/31.5907 = 0.0443
0.0443*sin-1 = 2.54
a and c is my to changing variables controlling the angle.
Regards
Henrik
Replies (10)
Message 2 of 11
_gile
There's no built-in function, but you can build your own.
;; gc:asin
;; Returns the arc sine of the number
;; Argument
;; n : the angle sine
(defun gc:asin (n)
  (cond
    ((equal n 1. 1e-9) (/ pi 2.))
    ((equal n -1. 1e-9) (/ pi -2.))
    ((< -1. n 1.)
     (atan n (sqrt (- 1 (expt n 2))))
;; gc:acos
;; Returns the arc cosine of the number
;; Argument
;; n : the angle cosine
(defun gc:acos (n)
  (cond
    ((equal n 1. 1e-9) 0.)
    ((equal n -1. 1e-9) pi)
    ((< -1. n 1.)
     (atan (sqrt (- 1. (expt n 2))) n)
Gilles Chanteau
GileCAD
GitHub
Message 3 of 11
hak_vz
(defun asin (x)
      (cond
        ((and(> x -1.0)(< x 1.0)) (atan (/ x (sqrt (- 1.0 (* x x))))))
        ((= x -1.0) (* -1.0 (/ pi 2)))
        ((= x  1) (/ pi 2))
(defun acos (x)(cond ((and(>= x -1.0)(<= x 1.0)) (-(* pi 0.5) (asin x)))))
Miljenko Hatlak
Message 4 of 11
Henrik_Lo
HI tangs for replying
Iam not familiar by using functions like that gc:asin
(Defun c:arcc ()
   (setq nnnn (GetReal))
   (setq angg (gc:asin nnnn))
Regards
Henrik
Message 5 of 11
Kent1Cooper
There are routines for all possible trigonometric functions that AutoLisp doesn't already include, in AutoLisp functions, in various places, one being >here<.
Kent Cooper, AIA
Message 6 of 11
Henrik_Lo
Hi Kent
I will give it a tray, to see if I can use these functions
Regards
Henrik
Message 7 of 11
Henrik_Lo
Hi Kent
Can you show me ha I could build up my base lisp program
And the using some of the add in functions it need to return 2.54 degree, iam not familiarized
Using prebuild functions
0.0443*sin-1 = 2.54
How do I build it into fx. this function
(Defun c:trrr ()
(Setq a (getreal)) ; 1.3
(Setq c (getreal)) ; 31.5907
(setq ac (/ a c)) ; 0.443
) ;The output need to be in degree , 2.54Degree
Regards
Henrik
Message 8 of 11
hak_vz
Here are functions to convert from radians to degrees and opposite. Functions sin cos....asin and so on require angle to be entered as radians and provide result in radians. So if you enter angle in degrees conver them to radians before ading ro trigonometric function, and final result convert back to degrees.
(defun rad_to_deg (rad)(* 180.0 (/ rad pi)))
(defun deg_to_rad (deg)(* pi (/ deg 180.0)))
Miljenko Hatlak
Message 9 of 11
Henrik_Lo
HI hak_vz, thangs
regards
Henrik
Message 10 of 11
_gile
Here's an example of what you describe with some comments:
(defun c:trrr (/ a c ac rad deg)	; local variables
  (setq a (getreal))			; 1.4
  (setq c (getreal))			; 31.5907
  (setq ac (/ a c))			; 0.0443
(terpri) ; print a newline (princ (rtos ac 2 4)) ; print the sine with 4 digits (setq rad (gc:asin ac)) ; angle in radians (setq deg (* rad (/ pi 180.))) ; angle in degrees
(terpri) ; print a newline (princ (angtos rad 0 2)) ; print the angle in degrees with 2 digits (princ) ; exit silently )
Gilles Chanteau
GileCAD
GitHub
Message 11 of 11
Henrik_Lo
HI gille, thangs
This is fantastic, now I know how to use intergraded function, cut out I heavy paper for me, thangs
Regards
Henrik
