Hi all,
I'm currently learning how to make a LSP, and I'm in the middle of getting familiar with the coding environment and variables.
My goal is to make a lisp that takes a polygon rectangle and transforms it into a serpentine line as shown below. I think for starters, i'll probably try to transform a polyline into an arc or a spline with a fixed radius, and then from there try to figure out how to turn a polygon into a serpentine polygon.
If you guys have any suggestions as to how to tackle this piece of code, it would be greatly appreciated. Also, if you guys have any resources for learning LSP and/or things I should look up, that would also be greatly appreciated as I start learning lisp coding.
Thanks!
-jesse
