tracking command in autocad
im trying to create a plot command, which is a modifing version of the old one that print automaticly.
i have posted old question to get the "windows" command and i got the command :
mr-_-small,
put this macro in your button...
^C^C-PLOT;Y;;;;;;;W;752.3389,680.5393;641.0157,524.6924;;;;;;;;;;
the best way is to write macros is using the command-line version.
of the command you want to use, and see how many enters are needed and the required options...
Hope that helps,
Henrique
i dont know how to use command-line version what is it ?
i want to know what is the commands referance for all plot options.
Kent1Cooper
The command-line version of any command is the way it works at the Command: prompt line, without a dialog box for those commands that normally use one.  Type the command name with a preceding hyphen to suppress the dialog box, in this case:
-PLOT
and follow it through, keeping track of your responses to all prompts.  Put them into order as in hmsilva's suggestion, substituting a semicolon for every Enter required, including the ones that "register" the command name itself and each response with content such as the Window corners.  In many cases a space works the same as an Enter, but when you have several in a row, it's easier to count them in the macro if they're semicolons.  The ^C^C at the beginning may not always be necessary, but is the macro-language way to cancel any command that may be running when you pick on the menu item that holds the macro [typically done with two cancels that way, in case you're in a command that needs two to get out of it].
Run the macro, and if it doesn't work, look at the last prompt and/or the error message, and you should be able to figure out whether you need an additional Enter/semicolon somewhere, or one fewer, or a different kind of input somewhere.
Kent Cooper, AIA
thats it, that what im looking for.
thank u very much man.
now i can make alot of lazzy codes xd.
owenwengerd
@Kent1Cooper wrote:
Type the command name with a preceding hyphen to suppress the dialog box...
Just to be clear, the hyphen does not suppress the dialog box. It is a convention to name the command line version of a command with a hyphen as the first character, but the hyphen has no special meaning.
Owen Wengerd
ManuSoft
