TOOLPALETTEPATH: Checking for a certain palette
I need to run a check to see if a certain tool palette group is loaded, with LISP.
I can retrieve the loaded tool palettes with the below code:
(setq CurrentToolPalettes (getvar "*_toolpalettepath"))
The issue i'm having is, how to step thru the list to check for a certain palette group.
SeeMSixty7
I feel like you aren't getting a whole lot of assistance on this one. I've looked a little but have not had an opportunity to dig into this yet. Just letting you know someone is thinking about it, even if I haven't looked into it enough yet to provide any feedback. I saw your last post as well and all the feedback(lack of) you got on that one.
Glad to see you got to another step.
Good luck,
Thanks for the response.  I'm also still digging deep on this one, but so far have not figured it out.
I can retrieve the tool palette paths with (getvar "*_toolpalettepath"), but can't figure out how to look for a certain group path from the list.
