toolbar colors
toolbar colors
markruys2
toolbar colors
markruys2
i have noticed that the toolbar colors for dark/light backgrounds are totally different,
for example look at the osnap toolbars, in light background the dots are red, while in the dark they are green.
how is autocad storing these png/bmp in the cuix file, for example the toolbar RCDATA_16_OSNTMP & RCDATA_32_OSNTMP
are the same names for dark and light backgrounds.  hope my question is clear.
TIA
Johanna_Esteban
You can customize with OPTIONS, DISPLAY tab, everything in terms of colors and backgrounds, when you have ready the configuration you want you can save it in the tab PROFILE, ADD TO LIST and assign a name, then APPLY and CLOSE.
You can switch between profiles according to your need without having to configure each color you need each time.
In addition, this profile you can EXPORT so that you can use it in other equipment that you use.
The settings of the colors of AUTOCAD itself, you choose it by the tab DISPLAY, COLOR SCHEME.
Johanna Esteban
Autodesk Expert Elite | Autodesk Certified Professional | AutoCAD Customer Council (Beta Tester for Windows & Mac)
¿Te ha parecido útil este post? ¡Dame Kudos! 😉
Si ha sido resuelta tu inquietud, selecciona 'Marcar como solución' para que otros usuarios la encuentren fácilmente.
cadffm
Programm Data/Autodesk/Autocad 2018/ *.xmx
In this two files the standard icons stored.
Programm files/autodesk/autocad 20xx/different *.dll
The Question for exactly answer: which Programm, which version, which Icon.
Sebastian
