Tool -Layer name check for number of characters and structure of layer name
nilesh33
Message 1 of 8
nilesh33
Hi Friends,
I would like to develop utility/tool/cad standard checker which will do following.
1. It will check and report if layer name contains more than 11 digits/letters/characters
2. It will check and report if layer contains characters as per predefined list or not.
Example first two characters in layer name should be from this list (T-, V-, R-, K-, ...etc)
What would be an easiest and efficient way to develop this?
Nilesh
Replies (7)
Message 2 of 8
Moshe-A
@nilesh33 hi,
the easiest way to to write a command to do these checking and run it from appload (or acad.lsp)
but in mid session it would be left unchecked (until next open).
a complemetry moudle to it, is using activex reactors to online check each change in layers
post some code if you already have?!
moshe
Message 3 of 8
DannyNL
Some quick 'n dirty example code.
Running (Test) will return all layer names which do not start with one of the prefixes in the list or with a length larger than 11.
(defun Test (/ T_LayerPrefixList T_LayerNameMaxLength T_LayerCollection T_LayerName T_Return)
   (setq T_LayerPrefixList '("K-" "R-" "T-" "V-"))
   (setq T_LayerNameMaxLength 11)
   (setq T_LayerCollection (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object))))
   (vlax-for T_Layer T_LayerCollection
      (if
         (and
            (/= (setq T_LayerName (vla-get-Name T_Layer)) "0")
            (or
               (not (vl-some '(lambda (T_Item) (wcmatch T_LayerName (strcat T_Item "*"))) T_LayerPrefixList))
               (> (strlen T_LayerName) T_LayerNameMaxLength)
         (setq T_Return (cons T_LayerName T_Return))
   (vlax-release-object T_LayerCollection)
   T_Return
Message 4 of 8
ronjonp
@DannyNL
FWIW..
;;This
(not (vl-some '(lambda (t_item) (wcmatch t_layername (strcat t_item "*"))) t_layerprefixlist))
;; Could be shortened to this
(not (wcmatch t_layername "K-*,R-*,T-*,V-*"))
Message 5 of 8
Moshe-A
yes @DannyNL,
it's true and works but it is also could be accomplish more simple way - NO?
   (SETQ T_Layer "[KRTV]-*")
      (if
         (and
            (or
               (not (wcmatch T_LayerName T_LayerPrefixList))
   T_Return
Message 6 of 8
Kent1Cooper
Investigate the STANDARDS command.
Kent Cooper, AIA
Message 7 of 8
ronjonp
Even simpler than mine 🙂
Message 8 of 8
DannyNL
And @Moshe-A.
Both correct......I sometimes forget that wcmatch supports bracketing Smiley Happy
