to get "boundingbox" of the blank space in a hatch
devitg
Advisor Advisor
devitg
Hi all , I need to get de so called, but I know it is not so, bounding box , of the blank space at a hatch . please see the attached DWG
I need the   "like" 'dl  'ur  .
Iwill use it  increased a bit to do a (ssget  "c"  -dl +ur  '( (0 . "HATCH")))
-dl is a point a bit downward   dl
and +ur is a point a bit upward  ur
Guess a 10 % more than distance dl ur
In fact I need to select the Hatch .
Kent1Cooper
In order to find the shape of the blank space, do you not need to select the Hatch pattern?  If you have it selected, can you explain the purpose of using the blank space in it as a basis for locations by which to select the Hatch pattern [again]?
Kent Cooper, AIA
devitg
@Kent1Cooper , please tell me how to select the text inside the hatch .
The hacth  have no boundary or whatsever way to select the text inside the blank area.
That is the fact.
I'm doing in reverse , selected the text , I can seletc the hatch by the
 (ssget "_C" -dl   + ur  '( ( 0 .  "HATCH )))
Kent1Cooper
That's different.  First it was about finding the hole in the Hatch pattern, with no reference to the MText; is it now about selecting the MText, and I assume figuring out the size of the hole from that?
If the Hatch was done with the MText as an island in it, the offset from the MText [as a percentage of its height or something] should be in some System Variable value I haven't been able to find.  I tried the TEXTMASK Offset value, but that's not it.  But even if it were, there's no guarantee it hasn't been changed since the Hatch was drawn, so using the current value may not be reliable.
I would start with the MText's bounding box, but the width of that comes from its defining-box width, which in the case of your sample drawing is very much narrower than the contents.  Still, some kind of expansion of that should still capture the Hatch pattern in a Crossing selection, but how to determine how much to expand around it is what I don't see how to do in a reliable way, unless someone can direct us to what determines the island area around Mtext when Hatching.
Kent Cooper, AIA
ronjonp
devitg
@Kent1Cooper .   Thanks for the explanation
