To filter a SSGET by APPIDname
devitg
Advisor Advisor
devitg
How it can be filter a SSGET by is APPID name ??
At the dwg , that come from CADWORKS , have appid named "CPD1" and "CPD2" .
It is a pipe 3d layout .
I use it
Code:
(setq ent (ssname (ssget ":s" '(( 0 . "3DSOLID"))) 0))
(setq appid-name  (caadr(assoc -3 (entget ent (list "*")))))
Thanks in advance.
Ranjit_Singh
Try below
(ssget "X" ’((-3 ("*")))); everything with extended data
(ssget "X" ’((-3 ("CPD1,CPD2")))); only particular appids
(ssget "X" ’((0 . "3DSOLID") (-3 ("CPD1,CPD2")))); 3d solids only with certain appid
devitg
Hi thanks for your help.
How I can use the appidname as a variable ?
as I told, I got the appid-name by
I try it
(ssget "X" ´((0 . "3DSOLID") (-3 (appid-name ))); 3d solids only with appid as a variable
And did not work
SSGET filter , always , bother me ,specially  I can get the way when variables are used
I know that in this case I shall use dotted pair , but did not get  how to .
Ranjit_Singh
(setq appid-name "CPD1")
(ssget "X" (list '(0 . "3DSOLID") (list -3 (list appid-name)))); 3d solids only with appid as a variable
Just left the computer so cannot actually test it but I believe it should work.
devitg
I will test it tomorrow , I closed my acad sesion .
devitg
Hi , it work  as need.
