to extrude with text in polyline
anycganycgJ8A6A
anycganycgJ8A6A
hi   i need some help ~
i found this code .
but there is error.
that code is   extrude with text.
there is  polyline ,  and   text in polyline.
if i select polyline ,    i would like to extrude   obj  as  txt value  .
(defun c:txtb (/ ss i sn pts n s in psn)
  (if (setq ss (ssget '((0 . "*POLYLINE"))))
  (repeat (setq i (sslength ss))
     (setq sn (ssname ss (setq i (1- i))))
      (if (and (vlax-curve-isclosed sn)
         (eq (- (fix (vlax-curve-getendparam sn)) (fix (vlax-curve-getstartparam sn))) 4)
       (progn
           (foreach x (entget sn)
          (if (eq (car x) 10)
            (setq pts (cons (list (cadr x) (caddr x)) pts))
           ( if (setq s (  ssget "_WP" pts '((0 . "text"))  )   )
           (progn
            (setq en (ssname s 0))
            (setq elist (entget en))
            (setq txt (cdr (assoc 1 elist)))
            (setq sum  (atof txt) )
            (command "extrude"  en  "" sum  "" )
  (princ)
Kent1Cooper
If I understand correctly what you want, try changing this:
to this:
(command "extrude"  sn  "" sum  "" )
The 'en' variable is the Text  object, but the Polyline  object is 'sn'.
Kent Cooper, AIA
