To box , and offset to an ATTRIBUTE
devitg
Advisor Advisor
Message 1 of 12
devitg
Hi all forum members, I'm dealing with this task .
To box a text string ATT, and offset it  and so on.
I can not get the way to get such LWpolyline coordinates to make it.
Up now,  I do this
As a matter of my way to do, I want to do it by VL-functions
Hope you could help me
Thank in advance
(DEFUN TO-BOX-AN-ATT  (/
                       ACAD-OBJ
                       ADOC
                       ATT-HEIGHT
                       BLK
                       BLK-ATT
                       BLK-ATT-INSPT
                       BLK-ATT-ROT
                       BLK-OBJ
                       BLK-SS
                       BOUNDING-ANG
                       BOUNDING-HEIGHT
                       BOUNDING-WIDE
                       MAXI
                       MAXI-XY
                       MINI
                       MINI-XY
                       MODEL
                       OFF-BOX
                       POLY-OBJ
  (VL-LOAD-COM)
  (SETQ ACAD-OBJ (VLAX-GET-ACAD-OBJECT))
  (SETQ ADOC (VLA-GET-ACTIVEDOCUMENT ACAD-OBJ))
  (SETQ MODEL (VLA-GET-MODELSPACE ADOC))
  (PRINC "\n select the block")
  (SETQ BLK-SS (SSGET "_:S+." '((0 . "insert"))))
  (SETQ BLK (SSNAME BLK-SS 0))
  (SETQ BLK-OBJ (VLAX-ENAME->VLA-OBJECT BLK))
  (SETQ BLK-ATT (CAR (VLAX-INVOKE BLK-OBJ 'GETATTRIBUTES)))
  (SETQ BLK-ATT-INSPT (VLA-GET-INSERTIONPOINT BLK-ATT))
  (SETQ BLK-ATT-ROT (VLA-GET-ROTATION BLK-ATT))
  (SETQ ATT-HEIGHT (VLA-GET-HEIGHT BLK-ATT))
; up now I got this
  (VLA-GETBOUNDINGBOX BLK-ATT 'MINI 'MAXI)
  (SETQ MINI-XY (VLAX-SAFEARRAY->LIST MINI))
  (SETQ MAXI-XY (VLAX-SAFEARRAY->LIST MAXI))
  (SETQ BOUNDING-ANG (ANGLE MINI-XY MAXI-XY))
  (SETQ BOUNDING-WIDE (ABS (- (CAR MINI-XY) (CAR MAXI-XY))))
  (SETQ BOUNDING-HEIGHT (ABS (- (CADR MINI-XY) (CADR MAXI-XY))))
 ; how to follow????????????????
 ; to make the lwpolyline
 ; i want to do it by VL-functions
  ;; once its done
  ;; offset
  (SETQ OFF-BOX (VLA-OFFSET POLY-OBJ (* 0.25 ATT-HEIGHT)))
  (VLA-PUT-COLOR OFF-BOX ACRED)
  (VLA-PUT-LINEWEIGHT OFF-BOX 1)
  (VLA-DELETE POLY-OBJ)
 ;|«Visual LISP© Format Options»
(180 2 1 0 nil "end of " 100 20 2 2 nil nil T nil T)
;*** DO NOT add text below the comment! ***|;
 Find attached the DWG sample
Replies (11)
Message 2 of 12
Sea-Haven
Will have to look for it again VLA-ADDPOLYLINE reads a safearray of points from memory.
here it is https://www.afralisp.net/archive/methods/list/addpolyline_method.htm
Message 3 of 12
pbejse
@devitg wrote:
how to follow???????????????? ; to make the lwpolyline ; i want to do it by VL-functions ;; once its
After you acquire the coordinates
(vla-AddPolyline model
               (vlax-safearray-fill
                 (vlax-make-safearray vlax-vbDouble '(0 . 14))
                 (append ll ul ur lr ll)
Or are you also looking for help to acquire the coordinates?
Message 4 of 12
pbejse
I wouldnt go with
Unreliable results, especially rotated objects,  use textbox function.
(setq blk-att-inspt (vlax-get blk-att 'insertionpoint))
(setq stringWidth
       (   (lambda ( box ) (- (caadr box) (caar box)))
            (textbox
                (list
	            (cons 01 (vlax-get blk-att 'Textstring))
	            (cons 40 att-height)
	            (cons 07 (vlax-get blk-att "StyleName"))
(setq 2nd&4 (mapcar '(lambda (a m)
               (polar blk-att-inspt (+ blk-att-rot a) m))
                     (list (/ pi 2.0) 0 )
                     (list  att-height stringWidth)
        3rd  (polar (Car 2nd&4) blk-att-rot stringWidth)
(setq poly-obj
         (append blk-att-inspt  (cadr 2nd&4 )
                 3rd  (car 2nd&4) blk-att-inspt)
(setq  off-box (Car (vlax-invoke poly-obj 'offset  (* 0.25 att-height))))
(vlax-put off-box 'COLOR  ACRED)
(vlax-put off-box 'Lineweight -1)
(vla-delete poly-obj)
 HTH
Im sure you have your reasons but you are not limited to using Vla-get to conform with VL functions rule, using vlax-get  gives the user an easily recognizable value and not a variant - no conversion necessary...
#<variant 8197 ...>
(vlax-safearray->list (variant-value BLK-ATT-INSPT))
(2880.55 1517.93 0.0)
Message 5 of 12
Sea-Haven
This could be replaced  (SETQ BLK (SSNAME BLK-SS 0)) with nentsel pick attribute as only 1 block and 1 attribute are having box added.
Message 6 of 12
Sea-Haven
I thought would change to nentsel. Sorry not tested no cad at moment.
(DEFUN c:TO-BOX-AN-ATT  (/
                       ATT-HEIGHT
                       BLK-ATT
                       BLK-ATT-INSPT
                       BLK-ATT-ROT
					   BLK-HEIGHT
                       MODEL
                       OFF-BOX
                       POLY-OBJ
(VL-LOAD-COM)
(SETQ MODEL (VLA-GET-MODELSPACE (VLA-GET-ACTIVEDOCUMENT (VLAX-GET-ACAD-OBJECT))))
(while (setq ent (nentsel "\nPick Block Attribute"))
(SETQ BLK-att (VLAX-ENAME->VLA-OBJECT (car ent)))
(setq stringWidth
            (textbox
                (list
	            (cons 40 (VLA-GET-HEIGHT BLK-ATT))
(setq poly-obj
  (VLA-PUT-LINEWEIGHT OFF-BOX -1)
  (princ)
 (c:TO-BOX-AN-ATT)
Message 7 of 12
devitg
@pbejse  Hi ,
Yes, of course, coordinates is the problem
Message 8 of 12
devitg
@Sea-Haven , the SSGET is used as it is part of a whole automation task , with,  almost, no user intervention.
There are about 6000 Blk-References
Message 9 of 12
pbejse
@devitg wrote:
..Yes, of course, coordinates is the problem
I realized that after i posted the question, Did you try the snippet i posted right after that?
Hope it helps.
Message 10 of 12
devitg
@pbejse , Hi , Yes,  I'm on it.
Seem to work , I have to fit it, to my need.
Message 11 of 12
Sea-Haven
If you want to do lots of blocks would it be better to go down the edit the block definition then attsync ? There is another post about add text mask to attribute.
Message 12 of 12
Sea-Haven
I have been playing with this and textframe is supported for mtext, the advantage is the box redraws if text is changed, the issue here is that a pline is being drawn around attribute, change the att value box does not update.
A possible method is to have Mtext in block with attribute invisible use the property of the attribute as the mtext value.
Ok next problem as I found out on another post when you use this method in master block it reads the master attribute object id so the mtext does not update when inserting, I wrote a lisp that reads the current block att id and reads the value setting the property correctly for the individual block. I thought I read somewhere here about setting the frame around the attribute.
This was add 3 atts display total in 4th att.
(defun c:test ( / obj lst x str)
(setq oldatt (getvar 'attdia))
(setvar 'attdia 0)
(command "-insert" "test" (getpoint "\npick point") 1 1 0 (getstring "\nEnter Att1 ") (getstring "\nEnter Att2 ") (getstring "\nEnter Att3 ") "-")
(setq obj (vlax-ename->vla-object (entlast)))
(setq lst '())
(foreach att(vlax-invoke obj 'getattributes)
(princ  "\n")
(setq lst (cons  (strcat "%<\\AcObjProp Object(%<\\_ObjId "
(vlax-invoke-method (vla-get-Utility  (vla-get-activedocument (vlax-get-acad-object))) 'GetObjectIdString att :vlax-false)
">%).Textstring>%"
 ) lst ))
(setq str nil)
(setq x (length lst))
(setq str (strcat "%<\\AcExpr ("
(nth (setq  x (- x 1)) lst) "+"
(nth (setq  x (- x 1)) lst) ")>%"
(setq x 1 y 4)
(if (= x y)
(Vla-put-textstring att str)
(setq x (+ x 1))
(setvar 'attdia oldatt)
(princ)
(c:test)
