through Lisp i want to add civil 3d pipe structure lable
ganeshkumar_duraisamyGAGVW
i was trying to write using command  function of civil 3d command when it comes to the selection object which i select through lisp of (ssget function) it is not taking
i request you to suggest me.
defun c:3dlabel()
(vl-load-com)
  (command "osmode" "0")
  (command "cmdcho" "0")
  (setq cnt 0)
  (setq structureset (ssget '((0 . "AECC_STRUCTURE"))));ADDNETWORKPARTPLANLABEL
  (if (/= structureset nil)
    (progn
      (setq totalcnt (sslength structureset))
      (while (>= totalcnt totalcnt)
(setq structure_obj (ssname structureset cnt));(vlax-ename->vla-object
(setq c3dobj (vlax-ename->vla-object structure_obj))
(setq strc_coord (vlax-ename->vla-object structure_obj))
;;; (command "")
(command "_AeccAddNetworkPartPlanLabel" c3dobj "")
;;; (setq strc_xy (vlax-get-property strc_coord 'Position))
;;; (command "ADDNETWORKPARTPLANLABEL" structure_obj)
;;; (setq sellab_Obj (entlast))
;;; (setq newlabpt1 (getpoint "\n Pick point to align.."))
;;; (setq newlabpt (getpoint newlabpt1 "\n Pick point to align.."))
;;; (command "stretch" structure_obj "" (setq basept1(getpoint)) (getpoint basept1))
(setq cnt (1+ cnt))
  (princ)
hosneyalaa
Moshe-A
@ganeshkumar_duraisamyGAGVW hi,
Do not have civil 3d but check this.
Moshe
(vl-load-com) ; load activex support
(defun c:3dlabel (/ savOSmode structureset structure_obj ;| local variables |; )
 (command "._undo" "_begin")
 (setq savOSmode (getvar "osmode"))
 (setvar "osmode" 0)
 (if (setq structureset (ssget '((0 . "AECC_STRUCTURE")))) ;ADD NETWORK PART PLAN LABEL
  (progn
   (foreach structure_obj (vl-remove-if 'listp (mapcar 'cadr (ssnamex structureset)))
    (command "_AeccAddNetworkPartPlanLabel" structure_obj "")
   ); foreach
  ); progn
 ); if
 (setvar "osmode" savOSmode)
 (command "._undo" "_end")
 (setvar "cmdecho" 1)
 (princ)
); c:3dlabel
