The insert block command with attributes copied from excel does not work.
JackTryMC
Message 1 of 11
JackTryMC
Hi, I have been using the excel provided by Lee Minardi generating the content of the insert block command on this forum and unfortunately the generated command content is not working.
I have set ATTDIA to 0, also I have set OSMODE to 0.
Attached the excel I was using and the block in .dwg I am using. Maybe there is something wrong with my block?
Thanks for any help!
Replies (10)
Message 2 of 11
johnyDFFXO
Check also ATTREQ
Message 3 of 11
JackTryMC
I changed ATTREQ to 0, not help.
Message 4 of 11
johnyDFFXO
That makes me wonder why did you do that?
Message 5 of 11
JackTryMC
I don't understand your question. I changed ATTREQ because that's what you suggested in your answer.
Message 6 of 11
johnyDFFXO
🙂Oh, I didn't suggest that.
Message 7 of 11
hosneyalaa
Message 8 of 11
JackTryMC
Nice. Unfortunately it still doesn't work. I'm using AutoCAD LT 2024 and when I paste it pops up an unknown command message. I have pasted rows from an excel sheet and made a script and it doesn't work either.
Message 9 of 11
johnyDFFXO
Take just one row and paste it into the command line. Then fit F2, make a screenshot and paste it here. If you get unknown mas, we need to see that.
Also, do you use English version of acad?
Message 10 of 11
JackTryMC
Polish version.
Polecenie - command
nieznane polecenie - unknown command
Message 11 of 11
johnyDFFXO
-insert is the command name in English which your Polish version does not understand.
So either use the Polish equivalent or add the underscore prefix.
_-insert
