Textual Xrefs list - Status (Loaded or Not Found) and Path
Hello everyone.
I'm trying to show a textual Xrefs list that includes the Status (Loaded or Not Found) and Path (see the image attached) inside the drawing.
I already used the expression $(xrefs,3) but it doesn't shows the Status (Loaded or Not Found), it only shows the path.
Could someone have an idea for do that?
Cheers,
ICárdenas
john.vellek has embedded your image(s) for clarity
Replies (7)
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 Can you show me how you are entering this expression?  Your image shows "Loaded" and "not Found".
John Vellek
Hello John:
The image that I attached is the hypothetical form as I would like it to be shown when a reference is loaded or not found.  For the previous image I added manually the loaded and not found text.
I attached the image of the expression that I used.
I hope that you can help me.
Cheers,
ICárdenas
ВeekeeCZ
Use the REFERENCE MANAGER.
With this utility you can do that and even more!
cadffm
@ВeekeeCZ "With this utility you can do that " I don't think so that you can create a text inside
your drawing with the information  of xrefname, xrefpath and xref state
(it is not possible except with a program extension, no ootb -way to get this information into a drawing object.)
Sebastian
ВeekeeCZ
Ok, you're right. My misreading. Thanks for the correction. But it would be nice and expected to have it though.
@Anonymous, sorry.
cadffm
I agree and i want this as native function and not only as a not supportet,
just for fullversions available, expresstools extension.
Sebastian
Dear all:
The main reason that I need  a routine to create a text inside my drawings with the information  of xrefname, xrefpath and xref state is for Quality Control. I have a big staff, many Xrefs files and a lot of DWG that dependes that each one will shows the correct information.
