Text value divide by 2
jyan2000
jyan2000
Hello Forum,
Is it possible to change all text/mtext value divided by 2? ( exp:  text / mtext =   12.2 / 2 : result should be 6.1 )
 Best Regards
Victor.
devitg
@jyan2000  test it
(defun c:t/2 ( / ED TEXT$
  (setq text$
         (rtos (* 0.5 (atof (cdr (assoc 1 (setq ed (entget (car (entsel "\n SElect a text")))))))))
  ) ;_  setq
  (setq ed (subst (cons 1 text$) (assoc 1 ed) ed))
  (entmod ed)
) ;_  defun
, just for each one
jyan2000
Thank you very much for all your concern. Finallay I've found a lisp Mathtext.lsp perfectly solve my request.
Best regards
Victor.
devitg
@jyan2000 , but it will not work with formatted MTEXT .  Neither do my lisp work for formatted MTEXT.
But if work for you , seem to be your dwg have Text or Unformatted MTEXT
3wood
You can also try ALTEXT.
