text trimming
text trimming
nychoe1
text trimming
nychoe1
(defun C:p074 (/ tmp ss itm obj str pos)
(vl-load-com)
(if (not #div#) (setq #div# "/"))
(setq tmp (getstring (strcat "\nDivisor character: <" #div# "> ")))
(if (= tmp "") (setq tmp #div#) (setq #div# tmp))
(setq ss (ssget "_:L" (list '(0 . "*TEXT") (cons 1 (strcat "*" #div# "*")))))
(if (and #div# SS)
(repeat (setq itm (sslength ss))
(setq obj (vlax-ename->vla-object (ssname ss (setq itm (1- itm)))))
(setq str (vla-get-textstring obj))
(setq pos (vl-string-position (ascii #div#) str))
(vla-put-textstring obj (substr str (+ pos 2)))
);; repeat
);if
(princ)
I got this Lisp here.
this Lisp is trim selected texts with "/"
<selected text==>result>
textL/textR ==> textR
xxx/yyy     ==>yyy
t12pty/5678  ==>5678
but I want to trim like this...
textL/textR ==> textL
xxx/yyy     ==>xxx
t12pty/5678  ==>t12pty
please help... thanks friends...
Kent1Cooper
This line:
is replacing the text content with what is in the original string starting with the character after the dividing character, to the end.  To start from the beginning and end with the character before the dividing character, change that line to:
(vla-put-textstring obj (substr str pos))
Kent Cooper, AIA
ВeekeeCZ
Change taht line to this
(vla-put-textstring obj (substr str 1 pos))
nychoe1
Kent1Cooper
that is big help for me. thank you...
nychoe1
I have a big help.
one more thing...
how to leave "/"
like this...
textL/textR ==> textL/
xxx/yyy     ==>xxx/
t12pty/5678  ==>t12pty/
ВeekeeCZ
(vla-put-textstring obj (substr str 1 (+ pos 1)))
nychoe1
I got it. thank you.
