Text so small at top overly large in the command window
I have a 2017 student version of AutoCAD
1) The command window type is so large it disrupts and makes it difficult to work in the drawing Im on
2) All of the type in the top dialog boxes does not show and when it does its so tiny you cant even see it with a magnifying glass.
ВeekeeCZ
You have hi-res monitor, hmm? You need to install 2017.1 Update. But I'm not sure it that is available for students version. @Alfred.NESWADBA will know.
Anyway, better you may get in Autocad forum, HERE@john.vellek can move it for you.
nikospur
Try changing the command line font in the Options Dialog box, Display tab, Fonts button. This might solve the command line font.
In the same Display tab, there are a couple of options for large buttons in toolbars and resizing ribbon icons. Play around with those and it might help with the other issue.
 look:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
Hope it helps!
