Basically I am inserting text via command saved in a text file (*.scr). I am calling ACCoreConsole.exe in conjunction with this script to insert the text into my drawing.
First, while using AutoCAD 2019LT I had a problem where the text inserted was snapping to nearby objects. I soon realised that Osnap was on, and turning this off resolved this.
Then I took my project from work to home, where I have AutoCAD 2021. The snapping problem is back. I have turned Object snap off and snap mode off (F3 and F11 respectively). The coordinates in the text file are correct but they are not when on the final drawing as it is always snapping to the nearest line or object.
Any ideas?
