Text inserting (from list)
BB8x
Message 1 of 16
BB8x
Hi all
Maybe one of you have something similar and want to share
I looking something what allows me to insert text from txt file
I can imagine this like:
  1. Run lisp
  2. Select file with texts (like 20 rows)
  3. Choose text from selected list
  4. Click pline
  5. Text appears aligned to pline (0.2 units away from pline)
  6.  Carry on to next pline
Replies (15)
Message 2 of 16
pbejse
  • Is there a central location for the text source file?
  • For every  pline "pick" the user will have to select a line of string from a list of some sort?
  • The text location is above or below the polyline segment?
Message 3 of 16
BB8x
  • Would be useful to choose txt file. One list for this task, other list for other task. Maybe one command would allow to choose and import file, second execute text from imported list
  • Yes something like this. Not always, but usually text is subject to change every click
  • Above
Message 4 of 16
stevor
One can get the string from the windows clipboard by:
https://www.cadtutor.net/forum/topic/53124-are-there-a-way-copy-and-paste-via-clipboard-by-lisp/
or maybe at LeeMac.com.
S
Message 5 of 16
pbejse
Post a sample drawing showing the desired result also a sample text file for the list
Message 6 of 16
BB8x
Example attached. Lines are base drawing. All texts are target and I need to put by hand
Message 7 of 16
pbejse
(defun c:Labelp  (/  notesFile opf pline str layer ppt ang file ipt str noteslist )
;;; 			pBe June 2021			;;;
(setq _trans (lambda (p)(trans p 1 0)))
	(if
	    (setq notesFile (getfiled "Selet notes file" (getvar 'dwgprefix) "txt" 16))
	    (progn
	    	(setq opf (open notesFile "r"))
		(while
		  (setq a (read-line opf))
		  (setq noteslist (cons a noteslist)))
		(close opf)
	      	(prompt "\nSelect Polyline:")
	    	(while (and
			 (setq pline (entsel "\nSelect Polyline"))
			 (member (cdr (assoc 0 (setq ent (entget (setq e (Car pline)))))) '("LINE" "LWPOLYLINE" ))
			 (setq str (Car (LM:listbox "Select notes to insert" noteslist 0)))
		(setq layer (cdr (assoc 8 ent)))
		(setq ppt (vlax-curve-getClosestPointTo e (cadr pline)))
		(setq ang (angle '(0.0 0.0 0.0) (vlax-curve-getfirstderiv e (vlax-curve-getparamatpoint e ppt))))
		(entmakex
		  (list (cons 0 "TEXT")
		                (cons 10 (Setq p_  ( _trans  (polar ppt (+ ang (* pi 1.5)) 0.2 ))
		                (cons 11 p_)
		                '(40 . 0.20)
		                (Cons 50
					(if (and
					(> ang (/ pi 2))
					(<= ang (* pi 1.5))
					)  (+ ang pi) ang ))
		                '(72 . 4)
		                '(73 . 3)
				(cons 8 layer)
		                (cons 1 str)
	  )(princ)
;; List Box  -  Lee Mac
;; Displays a DCL list box allowing the user to make a selection from the supplied data.
;; msg - [str] Dialog label
;; lst - [lst] List of strings to display
;; bit - [int] 1=allow multiple; 2=return indexes
;; Returns: [lst] List of selected items/indexes, else nil
(defun LM:listbox ( msg lst bit / dch des tmp rtn )
    (cond
        (   (not
                (and
                    (setq tmp (vl-filename-mktemp nil nil ".dcl"))
                    (setq des (open tmp "w"))
                    (write-line
                        (strcat "listbox:dialog{label=\"" msg "\";spacer;:list_box{key=\"list\";multiple_select="
                            (if (= 1 (logand 1 bit)) "true" "false") ";width=50;height=15;}spacer;ok_cancel;}"
                        des
                    (not (close des))
                    (< 0 (setq dch (load_dialog tmp)))
                    (new_dialog "listbox" dch)
            (prompt "\nError Loading List Box Dialog.")
        (   t
            (start_list "list")
            (foreach itm lst (add_list itm))
            (end_list)
            (setq rtn (set_tile "list" "0"))
            (action_tile "list" "(setq rtn $value)")
            (setq rtn
                (if (= 1 (start_dialog))
                    (if (= 2 (logand 2 bit))
                        (read (strcat "(" rtn ")"))
                        (mapcar '(lambda ( x ) (nth x lst)) (read (strcat "(" rtn ")")))
    (if (< 0 dch)
        (unload_dialog dch)
    (if (and tmp (setq tmp (findfile tmp)))
        (vl-file-delete tmp)
    rtn
Command: Labelp
Select Polyline
HTH
Message 8 of 16
BB8x
Thanks pbejse. Did some checks and works as it should be. It even takes elevation, but I did not asked for it.
Lucky guess: I put ("LINE" "LWPOLYLINE" "POLYLINE")) and works with 3d polies as well
Message 9 of 16
Sea-Haven
Pbe has posted a excellent solution for me I demand load the external routines like Lee's list box code. So only 1 line needed, rather than having all the external code in your code.
(if (not LM:listbox)(load "ListboxV1-2.lsp"))
If the text file is less than say 20 lines have a look at Multi Radio buttons.lsp Is a library routine again, but makes a radio button dcl rather than a list box.
Message 10 of 16
pbejse
Glad it works for you. You are welcome anytime.
Cheers
Message 11 of 16
BB8x
This lisp as I wrote works good.
Would be a chance to modify this and inserted text would have current text properties? So far it insets text, but after changing texts to standard height and style texts are bit off base line and I need to move texts
Message 12 of 16
pbejse
Would it be easier if the user were prompt for a text height ( using current value of TEXTSIZE as default value) [ Option 1 ] instead of running the program and re-sizing the TEXT objects?
OR
use TOP CENTER or BOTTOM CENTER as insertion point so regardless of the adjustments on the height it will not cross the lines. [ Option 2 ]
Message 13 of 16
pbejse
(defun c:Labelp  (/  notesFile opf pline str layer ppt ang file ipt str noteslist txheight)
;;; 			pBe June 2021/Apr 2022			;;;
	(if (and
	    	(setq notesFile (getfiled "Select notes file" (getvar 'dwgprefix) "txt" 16))
		(setq txheight (cond ((getreal
        		(strcat "\nEnter text height <" (rtos (setq txheight (getvar 'TEXTSIZE )) 2 )
				     ( txheight )
	    (progn
	        (setvar 'Textsize txheight)
		(while
		(close opf)
	      	(prompt "\nSelect Polyline/Line:")
	    	(while (and
		(entmakex
		                (cons 10 (Setq p_  ( _trans  (polar ppt (+ ang (* pi 1.5)) (* txheight 0.50)))
		                (cons 11 p_)
		                (cons 40 txheight)
		                (Cons 50
					(if (setq b (and (> ang (/ pi 2)) (<= ang (* pi 1.5)))
					)  (+ ang pi) ang ))
		                '(72 . 1)
		                (cons 73 (if b 1 3))
				(cons 8 layer)
		                (cons 1 str)
	  )(princ)
Message 14 of 16
BB8x
Helps a bit. Thanks
Message 15 of 16
abdelrahman_bakryNXEVN
Community Visitor
Community Visitor
Hello, It is working fine.
But, I want to ask you if we can create the Mleader with text instead of just creating text.
Thank you
Message 16 of 16
RichardSF35V
Can you make into multi-leader with Mtext or option for multi-leader with attribute block, example from
100 Steel, I will have the option to get the 100 in block attribute over "steel (as description)" or without? And much better if they are linked so that the list change i can run "update"?
