Text in linetypes
Text in linetypes
jasongrieve
Text in linetypes
jasongrieve
Good Day,
I am creating a custom linetype for my company. I am using a symbol (U+25CF:Black Circle) in a text format.
The circle needs to fit exactly between two lines. When I modify the offset of the circle to center correctly on a straight line (Red Circle) it is not centered correctly around a arc (Blue Circle), and when I fix it around the arc it does not center correctly on the straight line.
I am unable to set the text justification to the center of the symbol circle, any advise or help please ?
Kent1Cooper
See >this post< for an explanation of why that happens.  You need a gap designation of half the actual gap size, and then to back off  the start-point of the "text" element with a negative X value [in addition to the negative Y value to move its base point downward from the path center-line].  If you don't understand the explanation there, write back....
Kent Cooper, AIA
