Text in block is blurry when zoom
daohaquang
daohaquang
I've set the pitch Z to 0 but the text in lock is still blurry, both when viewing and when printing, help meIMG.jpg
Sea-Haven
It is more than likely something to do with the TTF that is in the text style you are using, change the font in the style  and test. Get a different font if that works.
pbejse
Nothing a good specs cannot fix
daohaquang
thanks, i found that bug, out of habit I usually fix the Scale X, Y properties in PROPERTIES but don't fix the Scale Z, I don't use the Scale command
