Text height change by lisp
Message 1 of 23
I am looking lisp for changing text height. I have to change Mtext  height 100 to 150 in my drawing.
I know using by filter commend. I have to know change by lisp.
I hope any one can help me..
Thanks for advance.
sujinkutti.
Replies (22)
Message 2 of 23
Kent1Cooper
That should not be difficult, provided none of the Mtext has any internal  height assignments overriding the height of the Mtext object as a whole.  Do you need to change all  Mtext to a height of 150, or only Mtext that currently is 100 units high, leaving others alone?
Kent Cooper, AIA
Message 3 of 23
Hi..
I need to change only Mtext 100 to 150 other should be alone.
Thank you
sujinkutti..
Message 4 of 23
Kent1Cooper
You can do this with QSELECT:
then in the Properties palette you can change the height of all of them at once.
Kent Cooper, AIA
Message 5 of 23
Thanks for your reply,
I know the Qselect & filter comments, i'm asking about the Autocad lisp.
sujinkutti
Message 6 of 23
pendean
Community Legend
Community Legend
Message 7 of 23
@pendean wrote:
the LISP forum is over here https://forums.autodesk.com/t5/autocad-customization/ct-p/AutoCADTopic1
There is no this kind of answer...
Any one please advice me.
It's very helpful to me.
I have to change all Mtext height 100 to 150...
Thanks and regards,
Sujinkutti.
Message 8 of 23
dbhunia
Hi
Try this........
This only for "MTEXT"........
(defun C:DEBA ( / ff1 xx1)
(Setq selectionset (ssget "_A" '((0 . "MTEXT") (40 . 100.0))))
(repeat (setq N (sslength selectionset))
(setq Data (ssname selectionset (setq N (- N 1))))
(setq EntityData (entget Data))
(setq ff1(assoc 40 EntityData))
(setq xx1 (cons 40 150.0))
(entmod(subst xx1 ff1 EntityData))
(princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 9 of 23
@dbhunia wrote:
Hi
Try this........
(princ)
Hi..
Thanks for the reply.
It's working, It's awesome...
Thank you very much..
Sujinkutti.
Message 10 of 23
piyush.parihar24
Command: DEBA
; error: bad argument type: lselsetp nil
Above error for below LISP
@dbhunia wrote:
Hi
Try this........
(princ)
Message 11 of 23
ВeekeeCZ
@piyush.parihar24 wrote:
Command: DEBA
@dbhunia wrote:
Hi
Try this........
(princ)
Message 12 of 23
okarim6RZ7U
It doesn't modify all my Mtext. 😢
Message 13 of 23
ВeekeeCZ
MTEXT uses two ways of defining text height:
- the height property, which is changed by the above routine - GREEN
- formatting characters, which could be applied just on a portion of text - RED
Google for STRIPMTEXT routine. It can remove all/some formatting characters if that is your issue.
Message 14 of 23
okarim6RZ7U
I ran a stripMText lisp for height. But it still doesn't affect RED after running the above routine. How do I make RED and GREEN match?
Like you said all values of GREEN are changed by the above routine. Is there a routine for RED?
Message 15 of 23
ВeekeeCZ
Generally, when you remove the char-formatting overrides, the above routine should work. Another thing is annotative scaling.
Post some dwg example to take a look.
Message 16 of 23
okarim6RZ7U
There are three text sizes even after running both routines. To make sure the stripMText works, I'm able to clear the linefeed that makes each text written on a single line. The height, however, is what I'm after.
GREEN for all the text is the same too (meaning the above routine also works). I just don't know how to match the GREEN and RED.
Message 17 of 23
ВeekeeCZ
Again and lastly, post a dwg. Before and target states.
Message 18 of 23
okarim6RZ7U
Alright.
Message 19 of 23
Kent1Cooper
Command: DEBA
That's because none of your Mtext objects have a height of 100 units that the code is looking for, but they're all [ignoring internal height formatting, or after STRIPMTEXTing them] defined with a height of 3/16".  [And even with internal overrides, they're 12 or 24 units in height, so I assume you do not want to change them to 150 units.]  So, since none of them have the height the code is looking for, the (ssget) function sees none of them, and the selection set is empty, which is exactly what the error message is about.
Kent Cooper, AIA
Message 20 of 23
ВeekeeCZ
From your target dwg it's not clear what your goal is.
Here I made a video before you posted the target.
https://autode.sk/3QmwP7k
My goal was to set all texts to the height of 24 (copied to the metric template).
HTH
