Text and mtext offset
jessicatyler0007
Message 1 of 9
jessicatyler0007
Hi All,
 Help me that I need to keep the text and Mtext at some distance from the polyline, and also rotate the text,Mtext along the polyline, is it possible?
The text has to manually input the distance from the polyline, I put the text in the test drawing at a distance of 100.
Replies (8)
Message 2 of 9
ВeekeeCZ
Here's one of my working tools.
(vl-load-com)
(defun c:MoveFromLine ( / ss pl i en ed et pc pt pp an fn tmp)
  (or *mtl-ds*
      (setq *mtl-ds* 0.))
  (if (and (setq ss (ssget '((0 . "LINE,LWPOLYLINE,ARC,CIRCLE,RAY,*TEXT,INSERT"))))
	   (progn
	     (while (not (progn
			   (initget "Copy")
			   (setq tmp (getdist (strcat "\nDistance from line [Copy] <" (rtos *mtl-ds* 2 2) ">: ")))
			   (cond ((not tmp))
				 ((= tmp "Copy")
				  (setq fn entmake)
				  nil)
				 ((setq *mtl-ds* tmp))))))
	     *mtl-ds*)
	   (or (and (setq pl (acet-ss-ssget-filter ss '((0 . "LINE,LWPOLYLINE,ARC,CIRCLE,RAY"))))
		    (setq pl (ssname pl 0)))
	       (and (setq pl (car (entsel "\nSelect a poline: ")))
		    (or (wcmatch (cdr (assoc 0 (entget pl))) "LINE,LWPOLYLINE,ARC,CIRCLE,RAY")
			(prompt "\nError: Wrong selection. Must be LINE,LWPOLYLINE,ARC,CIRCLE or RAY"))))
	   (setq ss (acet-ss-ssget-filter ss '((0 . "*TEXT,INSERT"))))
    (repeat (setq i (sslength ss))
      (if (setq en (ssname ss (setq i (1- i)))
		ed (entget en)
		et (cdr (assoc 0 ed))
		pc (if (and (= "TEXT" et)
			    (/= 0 (cdr (assoc 72 ed)) (cdr (assoc 73 ed))))
		     11
		     10)
		pt (cdr (assoc pc ed))
		pp (vlax-curve-getClosestPointTo pl pt)
		an (angle '(0 0 0) (vlax-curve-getFirstDeriv pl (vlax-curve-getParamAtPoint pl pp))))
	((cond (fn) (entmod))
	  (append ed
		  (list (cons pc (polar pp (+ an (/ pi 2)) *mtl-ds*))
			(cons 50 (setq an (if (= et "MTEXT")
					    (- an (angle '(0 0 0) (getvar 'UCSXDIR)))
					    an)
				       an (if (< an 0)
					    (+ an (* 2 pi))
					    an)
				       an (if (and (<= (if (= et "MTEXT")
							 an
							 (angle (trans '(0 0 0) 0 1) (trans (polar '(0 0 0) an 1) 0 1))) ; readable text mtext ucs
						       (* 1.5 pi))
						   (>  (if (= et "MTEXT")
							 an
						       (* 0.5 pi)))
					    (+ an pi)
					    an)))))))))
  (princ)
Message 3 of 9
pbejse
Quick one
(defun c:bugspray (/ d ref ss i e ent ipt npt ang)
  (if (and (setq d (getdist "\nEnter distance from reference line :"))
	   (princ "\nSelect reference line: ")
	   (setq ref (ssget "_+.:S:E" '((0 . "LWPOLYLINE"))))
	   (setq ref (ssname ref 0))
	   (princ "\nSelect the bugs: ")
	   (setq ss (ssget ":L" '((0 . "TEXT,MTEXT"))))
      (setq e (ssname ss (setq i (1- i))))
      (setq ent (entget e))
      (setq ipt (cdr (assoc 10 ent)))
      (setq npt (vlax-curve-getclosestpointto ref ipt))
      (setq ang	(angle '(0.0 0.0 0.0)
		       (vlax-curve-getfirstderiv
			 ref
			 (vlax-curve-getparamatpoint ref npt)
      (entmod
	(append	ent
		(list
		  (cons 10 (polar npt (+ (/ pi 2.0) ang) d))
		  (cons 50 ang)
  (princ)
HTH
Command: Bugspray
Enter distance from reference line :500
Select the bugs:
Select objects: Specify opposite corner: 17 found
Message 4 of 9
jessicatyler0007
@ВeekeeCZ @pbejse ,
your both lisp code are excellent, I am grateful to you.
Thank you very much
Message 5 of 9
jessicatyler0007
@ВeekeeCZ @pbejse ,
Please add another small option of text rotation to yes or no.
Message 6 of 9
pbejse
@ВeekeeCZ @pbejse ,
HYG [ refer to attached lisp file ]
(initget "Yes No")
      (if (null	(setq opt (getkword "\nRotate Text [Yes/No] <Yes>: "))
	(setq opt "Yes")
(cons 50
 (if (eq opt "Yes")
   ang
   rot
HTH
Message 7 of 9
jessicatyler0007
@pbejse
Thank you so much for your Help!!!
Message 8 of 9
ВeekeeCZ
Since both routines are pretty much the same ... the same suggestion would be applicable to my routine either.
Nice suggesting pbe, it's two in one! What productivity!
Message 9 of 9
marius_n_costea
Hello
It's and awesome lisp, I've been looking for such a lisp for a long time. Is it possible to add the option to move to 3D POLYLINES as well please? I don't know how to adjust the lisp.
Kind Regards
Marius
