Text and Change Dimension Text
k005
Advisor Advisor
k005
Hello friends;
How can we design this code to include normal texts and modified dimension texts?
Thanks in advance to the helpful friend.
(defun c:ymAlan (/ dg1 dg2 dg3 brl txtObj)
  (setvar "dimzin" 0)
  (defun get-dimension (ent)
    (if (setq obj (vlax-ename->vla-object ent))
        (if (or (vl-catch-all-error-p (vla-get-textoverride obj))
                (not (equal (vla-get-textoverride obj) "")))
            (/ (vla-get-textoverride obj) 100.0)
            (/ (vla-get-measurement obj) 100.0))))
  (setq msp (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-acad-object))))
  (setq txtH (getvar "Textsize"))
  (setq ent1 (car (entsel "\nÜst.ölçü seçiniz >")))
  (setq ent2 (car (entsel "\nAlt.ölçü seçiniz >")))
  (setq ent3 (car (entsel "\nYükseklik seçiniz >")))
  (setq pt (getpoint "\nNereye Yazılsın >"))
  (setq dg1 (get-dimension ent1))
  (setq dg2 (get-dimension ent2))
  (setq dg3 (get-dimension ent3))
  (setq brl (strcat "İstinat orta kısım Alan : ((" (rtos dg1 2 2) " + " (rtos dg2 2 2) ") / 2) x " (rtos dg3 2 2) " = "))
  (setq txtObj (vla-addtext msp brl (vlax-3d-point pt) txtH))
  (dos_clipboard brl)
  (princ)
Kent1Cooper
Does that actually work?  This:
surely gives an error, since a text override is a text string, not a number that the divide function can use.
I think what you want to do should be possible by using the DXF code 1 entry in entity data, rather than the "textoverride"  VLA property which would be applicable only to Dimensions.  The 1 entry is used for Text, short Mtext, and Dimension text overrides.  Something like this [untested]:
    (setq
      edata (entget ent)
      etxt (cdr (assoc 1 edata)); [M]Text content or Dimension text override
      (if (= etxt ""); Dimension without text override?
        (cdr (assoc 42 edata)); then -- use measured value
        (distof etxt); else -- use numerical equivalent of text override
      ); if
      100
  ); defun
Kent Cooper, AIA
k005
Yes. This is a part of the code you sent... namely the Text part. and it worked beautifully.
However, if the selection is a dimension text, then it did not make any calculations...
What I mean is that the code below must be combined with the code you sent.
        (if (= (vla-get-textoverride obj) "")
            (/ (vla-get-textoverride obj) 100.0))))
Kent1Cooper
That may be because I had an error in line 7 -- I had it testing "ext" instead of "etxt".  Now corrected -- try again.
Kent Cooper, AIA
k005
Thank you very much. Ok.
* However, if the numbers in the text are separated by commas, then it gives an error. It's okay if it's dotted...
For the TEXT..
example :
81,65 .... error
81.65 ... OK
So it would be great if a change function could be added. Make the comma a period. Just to make the calculations properly. Otherwise, there is no need to change the numbers...
Kent1Cooper
Change line 9 to say:
(distof (vl-string-subst "." "," etxt))
Kent Cooper, AIA
k005
In one word, it was Super.! 🤗   Thanks a lot @Kent1Cooper
