@bvyas
I can not do a lot without sample drawing.
What you can try is to use option Find and replace.
You can define your initial texts in a format (*) xxx' yyy" ......
And for search string to replace use *
Command: TCOUNT
Select objects: Specify opposite corner: 4 found
Select objects:
Sort selected objects by [X/Y/Select-order] <Y>: y
Specify starting number and increment (Start,increment) <1,1>:
Placement of numbers in text [Overwrite/Prefix/Suffix/Find&replace..] < Find&replace>: f
Enter search string <>: *
4 objects modified.
Miljenko Hatlak
![EESignature EESignature](http://autodesk.i.lithium.com/t5/image/serverpage/image-id/1272565i464DC3DC646B4F11/image-size/original)
