TCOUNT OR AUTOINCREMENT TEXT
bvyas
bvyas
Please see under:
need help in autoincrement of number juxt in parenthesis (1)S41 52 51W. When using TCount , Select Order it increments all instances of 1 in the above to 2 need only to increment 1 in parenthesis.
CodeDing
@bvyas ,
What kind of text object is that? (Text, MText, AEC Label, .....)
Can you post an example dwg?
Best,
~DD
hak_vz
@bvyas
I can not do a lot without sample drawing.
What you can try is to use option Find and replace.
You can define your initial texts in a format (*) xxx' yyy" ......
And for search string to replace use *
Command: TCOUNT
Select objects: Specify opposite corner: 4 found
Select objects:
Sort selected objects by [X/Y/Select-order] <Y>: y
Specify starting number and increment (Start,increment) <1,1>:
Placement of numbers in text [Overwrite/Prefix/Suffix/Find&replace..] < Find&replace>: f
Enter search string <>: *
4 objects modified.
Miljenko Hatlak
bvyas
It is Mtext
hak_vz
@CodeDing wrote:
@bvyas ,
Best,
~DD
@bvyasAre you sure this is the answer?  🙂
Miljenko Hatlak
CodeDing
@bvyas ,
Since MText is very unique in the manner of which it formats text, we would need a sample dwg to be sure we can help you best.
Best,
~DD
bvyas
Thank you for your help that works in TCount
